MIT iconn Regular Spade
EndersShadow
EndersShadow Posts: 17,717
edited May 2012 in Wanted (WTB) Classifieds
Anyone got some they dont need? Need a total of 4 or 6 for my EXp2 speaker wire. Thanks!
Post edited by EndersShadow on
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited May 2012
    Got some extra that fit on my AVT s3's. Don't know if they fit the exp series.
    edited May 2012
    leroyjr1 wrote: »
    Sent Jesse a PM asking that... let see what he says. My inital thoughts are it wouldn't make sense for them to NOT be universal, but who knows.....
    heiney9 Posts: 25,492
    edited May 2012
    They are universal across all MIT lines.
    If you can't find one, I may have some spares. But I need to locate them
  • Drenis
    Drenis Posts: 2,871
    edited May 2012
    You are in luck. I'm replacing 4 spades with i-conn nanners tonight as I just got them in from Joe Abrams.
    They are yours if you want them. However, 1 spade doesn't seat firmly on the i-conn end. It almost feels stripped but I think it may just be the way it was manufactured. Never the less, I had them secured and I never experienced any issues.
    Up to you.
    edited May 2012
    leroyjr1 wrote: »
    Looks like they do, and I would love to get 2 off you.
    Drenis wrote: »
    Up to you.
    I will gladly take em. PM incoming with my mailing address....
  • leroyjr1
    edited May 2012
    I'll put them in with the mount or we could trade spades for bananas
    edited May 2012
    leroyjr1 wrote: »
    If you could throw them in with the mount I would appreciate it. I need to mess with a couple different situations with my LSiC (wallmounted, etc) and so I need a set of spades for the EXp's since the bananas stick out to far if I wallmount.
    If I dont end up needing them I will ship em back to ya
