Why are some 2-way speakers assymetrical?
ambiophonics
The title says it all - "Why are some 2-way speakers assymetrical?"
It seems like it would be detrimental to imaging if you offset the tweeter to one side of the woofer, so why are some 2-way speakers designed this way, I've seen models from several companies setup this way, EPI, ADS, etc...
2 Channel - Polk SDA-2BTL, Triad SA1, 1000VA Dreadnought, Ryff streaming via Control4 for Qobuz lossless audio
Post edited by ambiophonics on
no thoughts?2 Channel - Polk SDA-2BTL, Triad SA1, 1000VA Dreadnought, Ryff streaming via Control4 for Qobuz lossless audio
"a" what??? LolMain Rig:
Nakamichi EC100 Active xover
MIT exp 1 ic's
Perreaux SA33 class A preamp
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable -
You mean something like this:
Honestly I think it is just to ease Manufacturing of them.
I prefer either mirror image or inline myself. Just seems weird to look at speakers sans grilles that look like this. -
probably should have spell checked first *asymmetrical
now I feel like an A$$2 Channel - Polk SDA-2BTL, Triad SA1, 1000VA Dreadnought, Ryff streaming via Control4 for Qobuz lossless audio -
Many times it's done due to combat diffraction. Depending on the drivers and cabinet, placing the drivers directly in the center may need a much more complex crossover than offsetting a driver or two."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
