Converting FLAC to Lossless WAV
  • bmbguy
    bmbguy Posts: 416
    edited May 2012
    gimpod wrote: »
    Usually if there is something that I need to do on the computer that doesn't warrant spending money on software or I can't find software that will do what I want it to do I'll write it myself.
    Opportunity knocks! If I were you, I'd write some 'on-the-fly' (whatever that means) FLAC decompression code that can be proven to be bulletproof -- and then sell it to all those who don't believe the current stuff works!
    One problem -- they might not believe that yours works either...
  • BlueFox
    BlueFox Posts: 15,251
    edited May 2012
    gimpod wrote: »
    Yes, PKzip files are pretty solid but if you look at the PKzip spec it says it's 99.9% accurate in its de-compression, so that leaves a 0.1% chance of an error. Granted it doesn't happen very often but it can and does. Don't tell me you've never ever had a zip file that wouldn't unzip.
    Just because errors are theoretically possible does not mean there is no such thing as lossless compression. If PKZip did not restore the original file they would have been out of business years ago. Sorry, lossless compression works.
  • CoolJazz
    CoolJazz Posts: 572
    edited May 2012
    Dubious? It's not back alley's that you hear this stuff! It's in the press even. I'm not making this up.
    To me this is back to that old "it's digital it's got to be perfect" thing. None of us have time for that...do we?
    Yes, I know you're serious about audio and I salute you for that! Seriously. But again I was only making the point that FLAC isn't the only choice out there...far from it. And btw...I'm serious about audio too. Made a living with it for over 30 years and much of that going through computer playback from the earliest genterations. Mpeg2, Apt-X. Soundcards galore. The difference in sync slaving to not. Analog with down to 40db S/N and the bandwidth not much more than a phone line but people wanting it sound good. I've fought with phone company dudes that don't have any idea what headroom is or what it means. I've had to have as many as 4 generational changes with a layer of lossy in between in a system end and end and tried to get quality out of it! I've seen the agony over change and don't want to relive some of those things. So if I don't see an album cover, I'm cool with that. If it's important to others, that's great for them.
    Some day it'd be cool to make a list of analog distortions and then make a list of digital distortions. They aren't the same at all! The problem with that is that it's so hard to put into words what you can just sit back and hear! It's more of a beer and easy chair topic than a white paper one. Take one of the flat earthers with the blinders on and you can make it all go away but when you want pure musical enjoyment then the little things all add up and do matter! On that (and Pass products), we agree! Rock on...
    Carry on' I'm out.
    CJ
    A so called science type proudly says... "I do realize that I would fool myself all the time, about listening conclusions and many other observations, if I did listen before buying. That’s why I don’t, I bought all of my current gear based on technical parameters alone, such as specs and measurements."
    More amazing Internet Science Pink Panther wisdom..."My DAC has since been upgraded from Mark Levinson to Topping."
  • bmbguy
    bmbguy Posts: 416
    edited May 2012
    BlueFox wrote: »
    I was just curious, so I checked -- nearly half of web sites are now sending compressed data.
    http://w3techs.com/technologies/details/ce-gzipcompression/all/all
  • Syndil
    Syndil Posts: 1,582
    edited May 2012
    gimpod wrote: »
    Wrong again, I've probably read, written and revise engineered more compressor/de-compressor source code than you have ever used. For starters Arc, Zip, Rle, Gif, jpeg, mpeg 1-4, huffman, wave, avi, and on and on.
    If that's true then you should know better. BTW show me where PKZIP claims only "99.9% accuracy." Methinks you like to talk out your rear...
  • bansheesho
    bansheesho Posts: 227
    edited May 2012
    Wow guys... I didn't know you all were so passionate about your audio formats. Lets keep the discussion back to information not flamming... lots of good information floating around.
    So I feel much more confortable using Media Monkey to convert FLAC to WAV....
    Original 96/24 FLAC file 77.6mb
    Crappy WAV one at 64mb and 85.9mb
    Media Monkey WAV conversion 128mb
    I feel much much more comfortable with Media Monkeys conversion
    Pioneer SC-25 | Adcom GFA-555 | KEF q900 Front | KEF q600 Center | Polk Monitor 30 Rear | Polk CS2 Rear Surround | Polk DSWPRO 660wi sub
  • gimpod
    gimpod Posts: 1,793
    edited May 2012
    gimpod wrote: »
    Wrong, If you look at how a compressor works i.e. removing repetitive and or reproducible patterns of bits & bytes from the source making the output smaller, Technically speaking how can you call it lossless when the compressor is throwing chunks of the original data away even though the de-compressor may or may not be able to reproduce the missing chunks hopefully without errors.
    BlueFox wrote: »
    I never said it didn't work. What I'm saying is that there is no such thing as a lossless compressed file. It is technically and mathematically impossible to do.
    Syndil wrote: »
    I can't seem to find that statement right now but I know I've got it somewhere, It's probably in one of the box's of programming stuff that I haven't unpacked yet after I had to move from last years great water heater incident.
    As a matter of fact PKZIP's site doesn't make any claims about it accuracy at all other than to say and I quote "PKZIP uses "lossless" compression so no original data is lost when a file is zipped." which makes me wonder if it was 100% accurate wouldn't it be good advertising to have that plastered all over there site. Now don't get me wrong I'm not knocking them they make a very good and reliable product and one that I use but like all software it's not perfect.
    Not to be too much of a **** but what part or parts of my statements don't you understand.
    Let me put it to you so even a 6 year old can understand - For example lets say that you have a file that is 100 bytes in size but after you compress it it is only 40 bytes in size, Guess what you've lost 60 bytes of the original file there for the compressed file can not be lossless. And if you can't understand that than I give up.
    Final word about compressed music, For a home server why bother with the cost of hard drives these days. I mean you can fit over 1400 uncompressed cds (at 700mb each) on one 1tb drive that would cost a lot less than a decent cd rack that could hold the same number of cds.
  • BlueFox
    edited May 2012
    gimpod wrote: »
    You aren't a ****, but you are an idiot. Of course the compressed file is smaller. That is the entire point of compression. :rolleyes:
    When your hypothetical example file of 40 compressed bytes is uncompressed then the resultant file is 100 bytes, and identical bit for bit with the original. That is what is meant by lossless compression.
  • Syndil
    Syndil Posts: 1,582
    edited May 2012
    gimpod wrote: »
    This illustrates why you obviously don't understand how compression software works. Those bytes aren't "gone," they're included in the decompression software's dictionary. Certain patterns are replaced with shorter patterns that are referenced to the longer patterns in the dictionary as the file is decompressed. This is why ZIP doesn't work well for compressing audio while FLAC does and vice versa--the dictionaries are tailored to the type of data that is being compressed.
    If I wanted to, I could write a compression program that would compress the entire contents of the Library of Congress in to a file no larger than 1KB. It would take a very large and specific compression dictionary, but it could be done. And once that 1KB file was extracted, it would absolutely contain a 100% accurate copy of the entire contents of the Library of Congress.
    PKZIP doesn't need to plaster "100% accurate" all over their page because it is unnecessary. Putting "100% accurate" on there would seem like a desperation measure, IMO. If it's lossless, do they really need to constantly preach about how accurate it is? No, they don't.
    Lossless is lossless.
  • unc2701
    unc2701 Posts: 3,587
    edited May 2012
    Yeah, gimpod, you are 100% wrong here, and I can show it in a very simple way:
    Take the following numbers:
    1234 1945 1220 1208 1005 1957 1379 1829 1782 1847
    I want to compress them. My algorithm is you subtract off n from the digits: this is the first number in a string. You use that n for the next x digits; x is the second number. so the original string becomes:
    1000 10 234 945 220 208 5 957 379 829 782 847
    Holy COW! That's less space. Can we get our original numbers back?... Yep! Ta da!
    That's a totally half-assed algorithm... a better one would recursively find the best n's to get the highest ratios. This is where the setting of compressors matter- you use more CPU when you compress, but the algorithms tend to be very asymmetrical: decompression is quite simple and not recursive.
    What you're missing is the difference between INFORMATION and data. Data can be highly inefficient. Information is an abstract idea that is the minimal representation of a set of data. You can theoretically reduce data down to its core information, and the degree to which a compression algorithm does that is its efficiency.
    Backburner:Krell KAV-300i
  • steveinaz
    steveinaz Posts: 19,545
    edited May 2012
    Look, we all know what a pain it is ripping hundreds (if not thousands) of CD's, and putting together your music library; we're simply passing on some info so later down the road you don't have a serious "aw ****" moment. I have compared wav to flac, streaming PCM rather than streaming flac (doing the conversion on the server), flac to CD---all of it sounds exactly the same. Take the info for what it's worth.
    EndersShadow Posts: 17,687
    edited May 2012
    LOL.... I found this and thought it somewhat applicable here:
  • mdaudioguy
    mdaudioguy Posts: 5,165
    edited May 2012
    When a metal spring is compressed, it still retains the same mass.
  • steveinaz
    edited May 2012
    The only possible differences might me found in the device/media (Hard drive vs optical transport), and "how" that data is read (armature/platter vs laser/CD). If differences even exist.
    Bottom line: Flac=Wav, but with far more flexible tagging; and uses less storage space.
  • gimpod
    gimpod Posts: 1,793
    edited May 2012
    You guys are so close to understanding what I'm saying that I'm going to give it one more shot.
    What you guys are not getting is the TERMINOLOGY. The term "lossless compressor" is a misnomer even though it is used through out the computer industry that doesn't make it right, Technically it should be "lossless decompressor". When you feed a uncompressed file into a compressor the compressor outputs a compressed file that can contain a reduced subset of the original data and or information that the decompressor can use to rebuild the original data that was in the original uncompressed file. What I'm talking about is the actual compressed file that is produced by the compressor not what is produced by the decompressor.
    So once again a compressed file and I say again "a compressed file" by the very nature of what the compressor dose can not be "lossless" and FYI the terms "lossy" and "lossless" in regards to file compression didn't come about until the advent of using compression for digital audio, video and true color images i.e. mpeg and jpeg for the most part, If I recall there were a few early compressors that were tried but didn't workout very well in terms of there ability to maintain acceptable quality and compressibility at the same time.
    BlueFox wrote: »
    Mr BlueFox thank you for showing your true colors and immaturity by resorting to public name calling. Let me assure you that even if and I say IF I thought you were an idiot I would never publicly say so or even say it to your face in private as it is an impolite and uncivilized thing to do. BTW Of course I realize the compressed file is smaller and at the same time it is not comparable to the original uncompressed file. That's the point I'm trying to make.
  • BlueFox
    edited May 2012
    gimpod wrote: »
    I stand by my statement. As you state:
    :rolleyes:
    Why are you wasting everyone's time on some stupid semantic argument? As has been said, you have no idea what lossless compression means.
  • unc2701
    edited May 2012
    :rolleyes:
    I now get what he's saying and it's completely pointless. I just realized I'd heard someone call "lossless compression" an oxymoron before and that guy was able to explain his flawed thought process a lot better.
    He's saying it's an oxymoron since the filesize is smaller. Thus, the filesize lost something when the file was compressed. In his terminology, Lossless means the filesize is all there, bit for bit. Compressed means it isn't.
    However, the rest of computer industry correctly uses "lossless" to refer to information NOT bits. If the original information can be stored in a format which uses less bits and can be passed through an algorithm which restores the original bits perfectly, it's called "lossless" by everyone (except gimpod).
    So to summarize:
    Lossless compression exists. It is an algorithm which stores the same information in less bits, and allows those bits to be restored perfectly. Different types of algorithms are made for different types of data. PKZIP was originally tailored for text; FLAC for 16bit wavs; there's even a lossless JPEG format made for pictures. It accomplishes this mostly by taking advantages in the patterns of numbers that represent the information stored. Furthermore, several of my clients use checksums to guarantee file versioning and I have NEVER had one come back wrong as a result of zipping/unzipping. On top of that I've actually done the exercise of converting to flac back to wav, burn, rip and checked against the original file with a 100% match. Lossless is lossless.
  • Gatecrasher
    Gatecrasher Posts: 1,550
    edited May 2012
    In the end, WAV, FLAC, WavPack, APE and all the rest of the "lossless" audio formats whether they are compressed or uncompressed result in an exact copy of the original uncompressed data.
    Currently the best overall format IMO is FLAC. It's the most-popular for good reason. I convert all the other formats to FLAC using dbpoweramp. The file size is smaller than WAV and it has better tagging.
    I can't imagine why anyone would prefer WAV to FLAC other than it is more native to Microsoft but there are codecs for Media Player that will play FLAC just as easily too so it's really not an issue worth bothering with for no other possible reason other than to have larger file sizes.
  • simionergo
    simionergo Posts: 1
    edited June 2014
    Faasoft's great Audio Converter is probably one of the best commercial choices though. With it, you can easily convert FLAC to WAV without quality loss. I used this tool for about a year and works like a charm.
    tonyb Posts: 33,065
    edited June 2014
    Is this the new "cables don't matter" thread. lol
    I guess the premise here is that a compressed file is some how inferior to an uncompressed file. Not sure if their is any truth to that at all on paper, but I've heard both and can say with certainty that I'll be damned if I can pick which is which. If I can't distinguish, then why in the world would I want to waste the added space it takes for a WAV file ?
  • Talon_Sr
    Talon_Sr Posts: 125
    edited June 2014
    It smells like testosterone in here. But don't fret, most forums are like this. That is what anonymity provides. If we were all in a room together we'd be laughing and drinking it up. You might think badly about someone, but you sure as hell wouldn't throw it out there publicly. This is just chat room "road rage".
    Pioneer SC-1523-K and VSX-1018AH-K; Polk Monitor 75T Fronts, Pioneer S-HF11C Center, Cerwin Vega VE-5M surrounds and backs; Polk PSW-505 with Mediabridge SW cable; Onkyo SKW-204 with Mediabridge SW cable; Oppo BDP-103; Akai GX-255 Open Reel.
