Distro block
mbdyer12
I just bought a Streetwires 4ga wiring kit and it came with a (1) 4ga in/ (4) 8ga out unfused distrobution block. If I've heard right, I still want to fuse each individual amp right at or just slightly below its fuse(s) rating. I'll be running about 90A (40A + 50A) and I have an 80A fuse in the fuse holder. Why would they include an unfused distrobution block with the kit? Can I just run 2 unfused 8ga wires from the 80A fuse to my amps and have them be protected by the 80A fuse? I dont wanna have to go out and buy more stuff. Haha...
2005 Subaru Impreza WRX
Post edited by mbdyer12 on
you should be good with what you've got. the fuses in the distro are, assuming everything else is in place, an extra level of security/safety. if you wanted, you could do two power runs, but that's a lot of unnecessary cable imo. i'd just use the distro.It's not good, very fundamentally simply not good. - geolemon
Seams a lot of amp companies are putting fuses on the amps now. Trend for a long time was "provide " your own. IF my amps have fuses...I dont use a fused distro...if they dont..I always have a fuse before my amp
i didn't bother putting fuses in front of hte 81000d's... i figured that if they were ganking more than their allotted 150-ish than considering all my other power draw, it would pop the individual 150A fuses on the two main 0 gauge power lines... now with a single 0 gauge line and a 200 A fuse, i belive this still holds true. all the other amps have fuses ON them.The Artist formerly known as PoweredByDodge
Ohh, all clear sir's. Thanks a ton. I also just got my Musica 500 Streetwires interconnect cable. $2.99 for 12 ft brand new in the box
eBay rocks.
Just to prove its good stuff: I had a cheap rca cable connecting the video out of my receiver to my tv and normally the ground loop noise was so bad that it drove me insane unless there was constant sound or music whlie playing my xbox or computer (tv as monitor).. I just hooked up one of the musica 500 cables to see if it would help out. The noise is practically gone. Since I have practically no electrical noise in the car, I'm pretty sure theres going to be none at all coming out the speakers now. I'm sold on this stuff. Theres still 3 left from the person I bought from if anyone needs some good (as far as I can tell) patch cable.2005 Subaru Impreza WRX -
i got my musica's last week and i love em... too bad i had to take my subs out like 2 days after.Originally posted by mbdyer12
eBay rocks.
Just to prove its good stuff: I had a cheap rca cable connecting the video out of my receiver to my tv and normally the ground loop noise was so bad that it drove me insane unless there was constant sound or music whlie playing my xbox or computer (tv as monitor).. I just hooked up one of the musica 500 cables to see if it would help out. The noise is practically gone. Since I have practically no electrical noise in the car, I'm pretty sure theres going to be none at all coming out the speakers now. I'm sold on this stuff. Theres still 3 left from the person I bought from if anyone needs some good (as far as I can tell) patch cable.cats.vans.bag... -
whys that?Originally posted by swerve
cuz im waitin on that second skin to get here... i prepped a week early.....
the secondskin will b here on mondaycats.vans.bag... -
sounds good
-Cody -
As said before a set of fuses after the distro block is just another level of security and is actually just easier for troubleshooting. If you blow the fuses in the amp and don't have the extra set of fuses, you might have to rip out the amps to check the fuses. Its generally easier to disconnect the power wire from a fuse holder and check the fuse that way.
... a good reason to have the extra set of fuses is if you decide to compete. I know SLAP, IASCA, and USAC all require fuses after any splitting of the power (ie distro block)Brian Knauss
ex-Electrical Engineer for Polk -
Thanks for all the replies. I don't know what I'd do without you guys. ::sniffs::2005 Subaru Impreza WRX
probably shrivel up and die...
they do that to prevent fire...something that doesnt go well with your vehicle...Originally posted by bknauss
