Dr. Spec...svs w/as-f2 waveform..how's this?
  • pjdami
    pjdami Posts: 1,894
    edited April 2004
    Yeah Steve you are almost "splitting hairs" there at this point. The error on the Rat Shack meter is probably +/- 1 db. Very nice looking curve. Where is the sub located? Middle wall of the room or in a corner?
    Looks like you are - 8 db at 20 hz so that 20 hz tune may flatten the curve even more on the low end and give you deeper extension.
    Is this a dedicated two channel rig only or will it be used for watching movies as well?
  • I-SIG
    I-SIG Posts: 2,243
    edited April 2004
    Steve's system is two-channel only. Like Steve, I'm starting to think that if I can get two channels to sound this good, why bother with surround, unless I want to be perpetually broke.
    On that 50XO setting, damn, that's like 2.5db's, +/-!
    Wes
    Link: http://polkarmy.com/forums
    Sony 75" Bravia 4K | Polk Audio SDA-SRS's (w/RDO's & Vampire Posts) + SVS PC+ 25-31 | AudioQuest Granite (mids) + BWA Silver (highs) | Cary Audio CAD-200 | Signal Cable Silver Resolution XLR's | Rotel Michi P5 | Signal Cable Silver Resolution XLR's | Cambridge Audio azur 840C--Wadia 170i + iPod jammed w/ lossless audio--Oppo 970 | Pure|AV PF31d
  • Dr. Spec
    Dr. Spec Posts: 3,780
    edited April 2004
    OK, you've got a great looking curve, and your stock extension is good enough for all music except true 32 foot organ.
    The $1M questions: How does it sound subjectively? Do you like the quality of the bass presentation for attack, impact, speed, detail, depth, cleanliness. Does it resolve complex/difficult passages? Bottom line - is the sub "musical", has it improved your 2-channel listening experience, and is it a good value?
    SVS
  • steveinaz
    steveinaz Posts: 19,546
    edited April 2004
    It's 2-channel only, but I do watch my DVD thru it. The SVS is in the left corner behind the left main. There's a diagram of my listening room in this sub-forum...
  • steveinaz
    edited April 2004
    At first I was alittle concerned, even with the curve looking as it did at 40Hz, the sound was a little "plummy" for my liking. That's why I continued to play with the crossover. 45Hz helped a little--but still over-bloomed a bit. 50Hz is doing the trick. Just the right blend.
  • HBombToo
    HBombToo Posts: 5,256
    edited April 2004
    Did you redo a curve at 50?
    OOOOPS I see now... sorry
    Henry
    ***WAREMTAE***
  • steveinaz
    edited April 2004
    I'd love to hear the SVS mated with some high-quality 2-way monitors, Like the Rti6, Lsi7 or Lsi9. I think in this setup, you'd have a hell of a system. I fact I've been thinking about it myself. You'd have the glorious midrange/treble of a relatively small monitor with the accurate deep-reaching bass of the SVS....*hmmmm*
  • phoneisbusy
    phoneisbusy Posts: 867
    edited April 2004
    *sigh*
    He's addicted... ;)
    Dave
    Time is the best teacher. Unfortunately it kills all its students.
  • PolkWannabie
    PolkWannabie Posts: 2,763
    edited April 2004
    Better yet ... http://www.polkaudio.com/home/technology/srtsats.php ... except of course that they're four way ...
  • steveinaz
    edited April 2004
    WOW! and they call those "satellites"??!! Holy smokes!
  • PolkWannabie
    edited April 2004
    Not the kind of thing you'd want to toss onto your average speaker stand, regardless of how much sand or kitty litter it was filled with.
