PWB Electret foil and cream
brgman
brgman Posts: 2,859
edited April 2012 in DIY, Mods & Tweaks
I am sure many others have read the review in the most recent Stereophile.(i think it was stereophile)
If this has been kicked around i couldn't find the thread.
So does anyone use this stuff?
Does anyone care to admit trying or using this stuff and telling me your findings?
thanks
I’M OFFENDED!!!!
Post edited by brgman on
  • Systems
    Systems Posts: 14,872
    edited April 2012
    The cream made me break out on my legs, so you may want to try the foil.
    Testing
    Testing
    Testing
  • brgman
    brgman Posts: 2,859
    edited April 2012
    pepster wrote: »
    i don't even wanna know where you rubbed it on!
    I’M OFFENDED!!!!
  • Systems
    edited April 2012
    brgman wrote: »
    No you do not want to know, GOOD DAY SIR!
    I SAID GOOD DAY!
    "Sounded good at the time"!:cheesygrin:
    Here is a link:
    http://www.belt.demon.co.uk/product/cream/cream.html
    External use only (trust me on this one).:cheesygrin:
    Testing
    Testing
    Testing
  • bmbguy
    bmbguy Posts: 416
    edited April 2012
    The battery compartment of remote controls and of battery clocks should have a thin coating applied and it will be found to be extremely beneficial if a thin coating is applied to the printed body of a battery. The outer face of electric and battery clocks should also have a thin coating applied.
    Well, my remote is extremely quiet. But my clock sounds fantastic.
  • Systems
    edited April 2012
    I have done my research, and according to the articles, I should not have used it the way I did.:wink:
    Testing
    Testing
    Testing
  • bmbguy
    bmbguy Posts: 416
    edited April 2012
    Belt: Right. When human beings don't like or react adversely to, say, capacitors of one sort, and we prefer those of another sort, it's not necessary that those capacitors are affecting the signal. It could be our reaction to their being present in the environment. That's the thing that changes the sound. That's sometimes why you can go to a capacitor that you found was the worst-sounding, and you can cream it with our cream, and that will [then] be the better-sounding?even better than the one that you preferred in the first place.
    And thus ends the capacitor wars...creamed.
  • brgman
    brgman Posts: 2,859
    edited April 2012
    I think if it works that good on everything you can just rub it on your ears and cover all the bases in one shot.
    I’M OFFENDED!!!!
  • bmbguy
    bmbguy Posts: 416
    edited April 2012
    Heck yeah. If it doesn't sting, I'll put it in my eyes too and throw my contact lenses away.
  • Systems
    edited April 2012
    bmbguy wrote: »
    Walker audio has sold millions of their silver past.
    I did not feel any silver, but it was smooth and silky none the less.
    Guess it depends on how you use it!:lol:
    I would be willing to try some of the foil for sure (hint brgman) but won't touch the cream again I can assure you!
    I will be gone for awhile as I have totally misused it at this point (I am on my way to the emergency room as I type this:eek:).
    Testing
    Testing
    Testing
  • brgman
    brgman Posts: 2,859
    edited April 2012
    is it like that other cream you bought to make you bigger?
    Now you have that Mickey Mouse right hand.
    I’M OFFENDED!!!!
  • Systems
    edited April 2012
    I am ambidextrous (Yeah I freakin had to Google that to spell it right, you got a problem with that?)!:cheesygrin:
    Testing
    Testing
    Testing
