PWB Electret foil and cream
brgman
I am sure many others have read the review in the most recent Stereophile.(i think it was stereophile)
If this has been kicked around i couldn't find the thread.
So does anyone use this stuff?
Does anyone care to admit trying or using this stuff and telling me your findings?
thanks
thanks
I’M OFFENDED!!!!
I’M OFFENDED!!!!
The cream made me break out on my legs, so you may want to try the foil.Testing
Testing
Testing -
i don't even wanna know where you rubbed it on!Main Rig-Realistic AM/FM Record player 8 track boasting 4 WPC
I’M OFFENDED!!!! -
No you do not want to know, GOOD DAY SIR!
I SAID GOOD DAY!
"Sounded good at the time"!:cheesygrin:
Here is a link:
http://www.belt.demon.co.uk/product/cream/cream.html
External use only (trust me on this one).:cheesygrin:Testing
Testing
Testing -
The battery compartment of remote controls and of battery clocks should have a thin coating applied and it will be found to be extremely beneficial if a thin coating is applied to the printed body of a battery. The outer face of electric and battery clocks should also have a thin coating applied.
Well, my remote is extremely quiet. But my clock sounds fantastic. -
I have done my research, and according to the articles, I should not have used it the way I did.
Testing
Testing
Testing -
Belt: Right. When human beings don't like or react adversely to, say, capacitors of one sort, and we prefer those of another sort, it's not necessary that those capacitors are affecting the signal. It could be our reaction to their being present in the environment. That's the thing that changes the sound. That's sometimes why you can go to a capacitor that you found was the worst-sounding, and you can cream it with our cream, and that will [then] be the better-sounding?even better than the one that you preferred in the first place.
And thus ends the capacitor wars...creamed. -
I think if it works that good on everything you can just rub it on your ears and cover all the bases in one shot.Main Rig-Realistic AM/FM Record player 8 track boasting 4 WPC
I’M OFFENDED!!!! -
Heck yeah. If it doesn't sting, I'll put it in my eyes too and throw my contact lenses away.
Walker audio has sold millions of their silver past.
I did not feel any silver, but it was smooth and silky none the less.
Guess it depends on how you use it!
I would be willing to try some of the foil for sure (hint brgman) but won't touch the cream again I can assure you!
I will be gone for awhile as I have totally misused it at this point (I am on my way to the emergency room as I type this:eek:).Testing
Testing
Testing -
is it like that other cream you bought to make you bigger?
Now you have that Mickey Mouse right hand.Main Rig-Realistic AM/FM Record player 8 track boasting 4 WPC
I’M OFFENDED!!!! -
I am ambidextrous (Yeah I freakin had to Google that to spell it right, you got a problem with that?)!:cheesygrin:Testing
Testing
Testing
