thing about a svs sub?
comet
i listen to a lot of music i was thinking about getting the 25-31 pc-plus or the pb2-ids. my reciever dose not have that good of bass management so what would be the best way to hook thier of this sub up. going threw the line/out level and use the sub to filter out bass from the mains?
thanks
comet
thanks
comet
Post edited by comet on
what kind of receiver do you have? is it a home theater receiver or a two channel one?
the nice thing about SVS subs.. is that you can try it out and return it within 30 days if not happy with it. As far as I know... no one has ever returned their SVS sub because they weren't happy with it.
PolkFest 2012, who's going>?
i have a marantz av9000
comet, i guess i should have also asked what you have for main front speakers. can they handle the bass? with most any subwoofer, you'll have a dial on the amp where you can turn up or down the bass level. most people run their subs a little hot.. you're Marantz should have a subwoofer output on it. that's the best and easiest way to hook up a sub.PolkFest 2012, who's going>?
the mains are linn keilidh the frequency response is 50hz-20khz+/-2db
