Avel Lindberg Y236906 Transformer - 800VA - For SDA Dreadnoughts
For sale - Avel Lindberg Y236906 Power Transformer
This power transformer can be used to make a Dreadnought for your SDA Speakers - replacing your interconnect cable, or for your basic - high-level, high-quality power transformer project.
Specifications:
800 VA
115 + 115 Secondary Voltage
3.48 Secondary Amperage
13.2 lbs
Full specifications can be found here:
http://www.avellindberg.com/transformers/y23_range_specs.htm
Asking $85 for anywhere in the CONUS. If paying by PP, add 3.3% fee, or send as gift.
Thanks.
MJ
Specifications:
800 VA
13.2 lbs
Thanks.
MJ
Statistics show that 98% of us will die at some point in our lifetime.
The other 2% will work for WalMart.
PM sent.
Money sent.
Sold to Schurkey. Schurkey, you will not be disappointed with the Torroidal. Shipping out later this week.
MJStatistics show that 98% of us will die at some point in our lifetime.
The other 2% will work for WalMart. -
Received about ten minutes ago. Thank you.
Well packed, and with the rubber washers, steel washer, and mounting bolt. Very pleased. -
I am just reading this now, as I just sent you the tracking info (busy week). Glad you got the package Shurkey!!! You would be most impressed that the box I shipped is the same box that AL used to ship me that same torroid.
:cheesygrin:Statistics show that 98% of us will die at some point in our lifetime.
Currently envisioning a formed stainless-steel-and-copper enclosure. Should be do-able for about ten dollars + wire terminals, and my labor.
I'm of the understanding that the "Member Sales Rating" system is broken, so I cannot leave positive feedback for you. Is that correct??? -
That is what I heard about the member rating system.Statistics show that 98% of us will die at some point in our lifetime.
