Best Floor Standing Speakers for under 1500
13»
    heiney9 Posts: 25,451
    edited April 2012
    newrival wrote: »
    To be fair, you should disclose that you have a large (read: massive) bias against emotiva. I have heard an XPA2 and thought it was pretty decent. And at least far from the horrendous atrocity you make it out to be. There are others here with experience equalling yours (subjective) that felt the emo amps are a good value and echo my sentiment.
    It will be if you pair it up with a pair of Maggies.
    edited April 2012
    newrival wrote: »
    And you and they are just as welcome to post your opinions.
    If you had really kept accurate tabs on my posts, I've said before for someone who is moving from a receiver to seperates for HT and want's new with a warranty, Emo isn't too bad. For 2ch music, not so much......
  • steveinaz
    steveinaz Posts: 19,545
    edited April 2012
    Music Direct has some BIG sales on a number of otherwise expensive Wharfedale and Focal towers...might be worth investigating.
  • Lietuvis91
    Lietuvis91 Posts: 909
    edited April 2012
    newrival wrote: »
    It's not exactly a secret that EMO amps can make some speakers sound uncomfortably harsh. Heard this experience too many times from different people who had to look for a different amp because of this issue. I'm sure it depends on the speaker being used though.
    Also, let?s not forget that room features: rugs, ceramic or wood floor, big windows, all can amplify or mute certain features of the sound. For this reason component selection can be quiet the science.
    So in this respect, results will always vary.
    Living Room 7.1 HT Rig:
    M70 | CS2 | M60 | Atrium5 - Surr. | SUB - Emotiva ULTRA12 + Tara Labs sub cable | Pioneer Elite VSX-52 | Parasound HCAs 1000A | Sony BDP-S790 | Belkin PureAV PF60 | MIT Exp2 Wires
    Bedroom 5.0 HT Rig (Music/Movies/Gaming) :
    LSi9 | LsiC | Lsi/fx | Marantz SR7002 | NAD T955 | Sony BDP-S360 | Belkin PureAV PF30 | AQ Blue Racer II ICs & AQ Type 4 wires | PS3
    edited April 2012
    ^^^ and associated gear, especially the source components.
  • Turbota
    Turbota Posts: 255
    edited April 2012
    steveinaz wrote: »
    Those Wharfedale EVO2-40 tower speakers with curved sides there selling look pretty impressive, and the price is great! Cabinet finish is wood veneer too (no vinyl). I noticed that they are a 6 ohm speaker.
    http://www.musicdirect.com/p-15535-wharfedale-evo2-40-tower-speakers-pr.aspx
    Now, if they only had the matching EVO2-10 bookshelf speakers.
    Speaker Type:.................2.5-Way Ported / Sealed Reflex
    Woofer:..........................1ea - 6.5" Woven Kevlar
    Midrange:.......................1ea - 6.5" Woven Kevlar
    Tweeter:.........................1ea - 1.0" Silk Soft Dome
    Cabinet Finish:.................Wood Veneer
    Rec. Amplifier Power:........50-300 w/ch RMS
    Nominal Impedance:.........6 Ohms
    Freq. Response:...............30 Hz - 28,000 Hz
    Sensitivity:......................89 dB
    Crossover (Sub-Mid):........150 Hz
    Crossover (Mid-High):.......2,200 Hz
    Dimensions:....................43.5" H x 9.0" W x 18.0" D
    Weight:...........................53 Lb. ea
    Wharfedale, along with Mission and Focal have reciently been bought of the the Chinese company called IAG Group. The speaker design and engineering still comes the UK, but the manufacturing now is in China.
    http://www.internationalaudiogroup.com/
    BTW .... These Wharfedale EVO2-40 tower speakers look very much the same as the Mission M66i floorstanders I have in the Philippines. Even have the same curved cabinet.
    2-Channel Audio
    Onkyo ... A-9050 . . .Integrated Amp. (Power Amp Section not Used)
    Onkyo ... M-282 . ... Power Amps .(Pair)
    Onkyo ... C-7030 . _.CD Player
    Polk . . *. RTi A7 - ....Front Speakers
    Polk . . *. RTi A3 - ....Rear Speakers
  • newrival
    newrival Posts: 2,017
    edited April 2012
    heiney9 wrote: »
    No bias at all, they plain sound just average to my ears, IMO. How that's considered a bias I don't know. I've heard the cdp and it was decent, but for it's price point one could do better, one could do worse. Heard the XPA1 and XPA2 and once could do a lot better, IMO.
    Horrendous atrocity????? Don't believe I have ever said that. I have listened to a lot of gear and Emo falls towards the bottom, it's not my cup of tea and anytime someone mentions brands like B&K, Parasound, Acurus, Adcom, Carver, Rotel, NAD, Sunfire and others in the same sentence wanting to know which to choose, I'll always choose the one (of those mentioned) that is NOT Emotiva because they just plain perform better, IMO.
    Because I have a preference and an opinion doesn't mean I am inherently "biased" against Emo. It means I prefer the sound of most other similar brands. If you want to take that as massive bias against, then that's your perogative (Bobby Brown).
    I used perhaps a touch too much hyperbole, but I would say you have come out more than strongly against emo an more than one ocasion.
    I can't say that I hve been keeping acurate tabs on your em comments, but I do recall some spirited battles on the subject of using them in 2 channel.
  • Drenis
    Drenis Posts: 2,871
    edited April 2012
    I'm sorry but those Wharfedale's are ugly IMO...
    newrival wrote: »
    They are simply opinions and how he voices it to the community. It's okay to share thoughts on products especially if you are familiar with it. Doesn't mean anyone has to take the remarks seriously or for their benefit. Also on the flip side, Brock has been seen recommending (You may have to do a search if you wish for visual proof) Emo for the HT crowd who like the pros of having a new product and warranty.
    I've never heard Emo so what can I say? Nothing.
  • bmor
    bmor Posts: 44
    edited April 2012
    Have you looked at PSB? The Image T6 is well regarded and I think within your price range at list price. They have B stock sales every now and then at 40% off, the latest was last fall. I picked up some Imagine T's on that deal and are more than happy with them. The walnut finish is gorgeous and they sound pretty good too.
    2 CH - SB Touch, CA 840C, CA 840Av2, PSB Imagine T
    HT - Pioneer 1325, Emo UPA-1, MA Silver RS series 7.1
  • robert0507
    robert0507 Posts: 148
    edited April 2012
    ok everyone I bit the bullet and ordered the LSIM 703. I figured they would make for some sweet to channel listening on my jazz collection, and also sound good with my Jay Z stuff too. I am also going to sell my emotiva xpa2 amp and get a nice parasound one. I might even get a tube amp. Does anyone know a quality tube amp for under 700$....Heiney9 im looking at you.....:eek:
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited April 2012
    Congrats!!! Haven't gotten into tube amps yet (don't think I ever will) but I've heard good things about the Anthem tube amp and it's in your budget. I'd also look at warmer SS amps like Parasound and B&K.
  • zingo
    zingo Posts: 11,258
    edited April 2012
  • robert0507
    edited April 2012
    leroyjr1 wrote: »
    Thanks. Im excited to get them home and all set up
  • leroyjr1
    edited April 2012
    Where did you buy them from? Do you have to wait on shipping?
  • robert0507
    edited April 2012
    Yeah i got them from polk direct. I figure if dont like them I could always return them. But I think I am going to like them.
  • ForceV4
    ForceV4 Posts: 14
    edited April 2012
    cnh wrote: »
    The Onkyo 3008 is a very nice AVR and the Emotiva has lots of power. But together that is "far" from the best combo for a set of Rti-A9s if you're more interested in "music". It is Great for HT, though!
    cnh
    My apologies for derailing this thread but I'm confused. Why is the above set up not a decent combo? I have RTI 12 and I understand they like power. Wouldn't the Emotiva have enough snort to keep the Rti A9s happy?
    Have a wheelie nice day!
    Yamaha RX-V3300
    Yamaha CDC-585
    Yamaha DV-C6480
    RTi12 mains
    CS400i center
    RTi38 r/l surrounds
    OWM3 presense
    PSW 202
    RTi100 B channel powered bedroom speakers
  • ravaneli
    ravaneli Posts: 530
    edited April 2012
    Drenis wrote: »
    Really?
    Wow.. you have some taste..
    BlueFox wrote: »
    I have found that tube based computers provide the best sound quality. ENIAC and MANIAC I offer a smooth, well defined and articulated sound unmatched by the current silicon based CPUs. :wink:
    But as in all things your perception is your reality.
  • Dawgfish
    Dawgfish Posts: 2,554
    edited April 2012
    Congrats on the purchase! I know you are going to be happy with the 703s. I am running an Anthem Pre-1L tube preamp and Anthem Amp-2 tube/solid state hybrid amp with my 703s and they sound awesome together. I just purchased an Anthem Amp-1 which is a pure tube amp and it arrived at home yesterday. I am working away from home, so it will be a couple of weeks before I get to hear it. The 703s and tubes go together like peanut butter and jelly! I am a jazz lover myself and this is a great combo for jazz. Also like Leroyjr1 has alluded to, warmer sounding amps like B&Ks sound great with the 703s also. I also have a B&K ST-202+ that sounds great with the 703s. The 703s really like the tubes though IMHO.
  • Dawgfish
    edited April 2012
    ForceV4 wrote: »
    It's all about synergy. I used to own a set of RTI-12s also and powered them with an Emotiva XPA-3, while using a Denon 2809 as my pre. This setup sounded outstanding for HT, but RTI-12s can be a little bright for two channel duties and the same thing holds true for the Emotiva amp. Paired together they are a little on the bright side of things for two channel listening IMHO. Also using an AVR as a pre for two channel duties is less than ideal. The RTI-12s can sound great for two channel listening and the newer A9s are a little smoother and sound even better for two channel listening, but when paired with a good two channel preamp and an amp that is a little on the warmer side of things like B&Ks, Parasounds, and any tube gear. Sound is a personal thing though and you may like things a little on the brighter side.
    tonyb Posts: 33,072
    edited April 2012
    Agree with the last 2 posters.
    Dawg- Tubes man, and Jazz ? Made for each other bro. Tubes give you a better appreciation for all kinds of music. Like making the hair on the back of your neck stand up and say, " WTF was that ? "
    Force- It's not all about power, but matching up the right gear with the right speakers to your set of ears. Obviously that will vary between different sets of ears, no ?
  • Dawgfish
    edited April 2012
    tonyb wrote: »
    Can we get an Amen in the house? LOL. Thanks for the kind words TonyB!
  • tacman1
    tacman1 Posts: 3
    edited July 2012
    i like bose stuff but definitive technology has great speakers too
  • nguyendot
    nguyendot Posts: 3,594
    edited July 2012
    tacman1 wrote: »
    Troll.
    Main Surround -
  • markmarc
    markmarc Posts: 2,309
    edited July 2012
    nevermind
    Former Staff Member TONEAudio
    2 Ch. System
