Interconnection cable for sda-1 speakers
I recently bought a pair of sda-1s but did not get the interconecting cable with them. I would like to find an original one or try to retro-fit one and not have the job look like some Franenstine operation.Can anyone give me some help/sugestions. Thanks.:evil:
Post edited by Ghost Rider on
  • Denzel
    Denzel Posts: 78
    edited April 2012
    Welcome to CP!
    There are a couple of forum members over in the Vintage Speakers forum that have scratch-built interconnect cables. What I did with two pairs of my SDA's was to replace the SDA connector with a Cardas binding post, and them use a single spade or banana cable to connect the two cabinets. The pin/blade style connectors only use the pin as an actual connection, the blade is just for stability, so a single speaker wire will work. If you have a blade/blade style, then you will need to use an XLR-type connector and use two leads (+ and -) of the speaker wire to make the connection work. I am going to do this to my SDA SRS's as they have the blade style connector. Take a look over in the Vintage Speaker forum and there is lots of info on the SDA series.
    Good luck!
    SDA SRS 3.1TL, Adcom GFP710 (preamp), GFA5400 amplifier, Pro-Ject TT
    SDA SRS (circa 1988), Integra DHC 60.3 (HT preamp) Adcom GFA555 II, CS400i (center), Monitor 4.6 II (rears) Adcom GFA2535 & Oppo BDP-103, TCL 55R617 55" 4K Display, RTA 15TL (crossovers by VR3), Adcom GFP710 pre & GFA545 II amplifier, NAD C545BEE. AppleTV 4K
    Other Polks not in service currently; SDA2a, SDA CRS+, SDA SRS 2.3, Monitor 4.6 II, Monitor 5jr+
  • bmbguy
    bmbguy Posts: 416
    edited April 2012
    We just had this discussion about building a blade-blade cable not long ago:
    http://www.polkaudio.com/forums/showthread.php?130466-Sda-2b
    Welcome to the forum.
    F1nut Posts: 51,913
    edited April 2012
    SDA 1's use a connector that resembles an XLR type connector. The only place you're likely to find an original is on eBay or in the Flea Market here.
  • Ghost Rider
    Ghost Rider Posts: 5
    edited April 2012
    Thanks to all for the help/ideas. My sda's have the pin/blade connections so I think I might try the single RCA pin aproach. I was suprised to hear that the blade was only used for support. Any more help or suggestions would be welcomed. Peace Out, G.R
    F1nut Posts: 51,913
    edited April 2012
    Then they cannot be SDA 1's.
    pitdogg2 Posts: 27,191
    edited April 2012
    Did SDA1c say so on the back label? I thought my SDA2A's were SDA2b for the longest time just because of pictures of the SDA2b studio and the oak topped model. Until I pulled the drivers and got my learn on here.
    I'm thinking they just say SDA1 on the back and that is were he gets the SDA1 from.
  • Ghost Rider
    edited April 2012
    After some looking at some pictures of various Polk's on the web I have found out that I have a pair of sda1c's. But in my own defence on the back of the speakers they are listed as only sda1. The more I look the more I find out about the Polk line. Still learing somewhere in audio land. Peace Out. G.R. :evil:
  • Ghost Rider
    edited April 2012
  • ronntech
    ronntech Posts: 1
    edited May 2012
    Your in luck. I have an original POLK AUDIO INTERCONNECT CABLE .. Approx 25 feet long with transformer. I could send pictures if you want. Let me know if you still need it.
  • Ghost Rider
    edited May 2012
    Yes, I would like to see the cable picks. Send picks to ghostrider56@ verizon.net Thanks! G.R.
  • dhart86
    dhart86 Posts: 1,594
    edited May 2012
    I'd be interested if Ghost Rider passes on this cable
    Main Rig:
    Antipodes DX > Roon > PS Audio Directstream Jr.>deHavilland Ultraverve 3 >Belles Reference 150a >Harbeth C7 ES3
    Second Rig:
    Roon> PS Audio Directstream Jr Bridge II > EE Minimax pre (Tutay mods) >Belles 150A Ref >Monitor 5 (Westmassguy-modded)
