Avel Lindberg Y236906 Transformer - 800VA - For SDA Dreadnoughts
PolkMaster1
For sale - Avel Lindberg Y236906 Power Transformer
This power transformer can be used to make a Dreadnought for your SDA Speakers - replacing your interconnect cable, or for your basic - high-level, high-quality power transformer project.
Specifications:
800 VA
115 + 115 Secondary Voltage
3.48 Secondary Amperage
13.2 lbs
Full specifications can be found here:
http://www.avellindberg.com/transformers/y23_range_specs.htm
Asking $85 for anywhere in the CONUS. If paying by PP, add 3.3% fee, or send as gift.
Thanks.
MJ
Specifications:
800 VA
13.2 lbs
Thanks.
MJ
Statistics show that 98% of us will die at some point in our lifetime.
The other 2% will work for WalMart.
Post edited by PolkMaster1 on
PM sent.
Money sent.
Sold to Schurkey. Schurkey, you will not be disappointed with the Torroidal. Shipping out later this week.
MJStatistics show that 98% of us will die at some point in our lifetime.
The other 2% will work for WalMart. -
Received about ten minutes ago. Thank you.
Well packed, and with the rubber washers, steel washer, and mounting bolt. Very pleased. -
I am just reading this now, as I just sent you the tracking info (busy week). Glad you got the package Shurkey!!! You would be most impressed that the box I shipped is the same box that AL used to ship me that same torroid.
:cheesygrin:Statistics show that 98% of us will die at some point in our lifetime.
Currently envisioning a formed stainless-steel-and-copper enclosure. Should be do-able for about ten dollars + wire terminals, and my labor.
I'm of the understanding that the "Member Sales Rating" system is broken, so I cannot leave positive feedback for you. Is that correct??? -
That is what I heard about the member rating system.Statistics show that 98% of us will die at some point in our lifetime.
