Dr. Spec...svs w/as-f2 waveform..how's this?
steveinaz
steveinaz Posts: 19,546
The settings:
40Hz...crossover freq
25Hz...Filter
Level...3 lines up from "min" (the line increment before half)
Phase...0
Post edited by steveinaz on
  • pjdami
    pjdami Posts: 1,894
    edited April 2004
    Very nice in room response Steve. That's the flattest looking curve I've seen besides Doc's.
    Your x-axis is a little confusing though. What's the freq of the third from the left dot at 90 db? You are using 5 hz increments except for the 18 hz all the way to the left. Not sure if the tick line for the freq is to the left or right of the number there.
    Looks really really good though. +/- 3 db almost with a radio shack decibel meter ( if that's what you are using). That's pretty awesome.
    So has your nervousness turned into euphoria yet?
  • nebborjk
    nebborjk Posts: 425
    edited April 2004
    That looks like a really nice graph. Looks like the SVS added quite a bit to the 20Hz. region. Are you using a PEQ? Seems most set-ups have a positive bump in the 30-40Hz. range and you don't. Looks good and I bet it sounds even better.
    Proud SOPA Member since 2005!
  • pjdami
    pjdami Posts: 1,894
    edited April 2004
    I think I may have answered my own question on the x axis. the numbers are actually the "in-between" tick marks?
  • steveinaz
    edited April 2004
    3rd dot from the left is 25Hz, the freq's are 18, 20, 25, 30, 35...and so on to 100Hz.
    I love this thing, does just what I'd hoped it would do...fills in the blanks from 40Hz-down.
  • steveinaz
    edited April 2004
    No PEQ, just the settings above with my Athena's running full-on.
  • steveinaz
    edited April 2004
    Here's a plot of the Athena alone, then the combination of the Athena and SVS:
  • gatemplin
    gatemplin Posts: 1,595
    edited April 2004
    Have you tried adjusting the phase to blend them better at about 40 Hz?
    Graham
  • steveinaz
    edited April 2004
    I haven't, I was wondering about that "area" too, there's a noticable dip from both the Athena alone, and the combo...I was thinking maybe I need to up the XO to 45Hz?
  • pjdami
    pjdami Posts: 1,894
    edited April 2004
    Better graph there Steve. Easier to understand the x-axis. Do both of your 8 inch drivers in the Athenas play the same frequencies or does one crossover into the other?
    If they both play the same frequencies you may want to experiment with bumping up the crossover to say 50 or 60 hz and see how that affects the midrange on the Athenas. It may allow those delicate voices in the midrange to sound more to your liking. Maybe not. Cool to experiment with though and let the sub do the heavier bass stuff.
    I'm assuming you are going to try the 20 hz tune next?
    Congrats by the way as well.
  • steveinaz
    edited April 2004
    Thanks Pjdami, I'm fine at 25Hz, though I'm going to try to iron-out that dip at 40Hz with the phase knob. The Athena's are a 2 1/2 way, I think...not sure. The SVS is really having a very subtle effect, and I like it!
  • gatemplin
    edited April 2004
    Try making 5 graphs with phase at approx 0, 45, 90, 135, 180 to get you in the ball park. When you find the flattest response do some more sweeps to fine tune. If you still have a dip then adjust the crossover.
    I think you can flatten that out just using the phase dial.
    Graham
  • steveinaz
    edited April 2004
    Ok, I'll give that a shot...
  • HBombToo
    HBombToo Posts: 5,256
    edited April 2004
    or increase the crossover frequency and plot 1 chart...
    or nevermind cuz I had a few beers.
    HBomb
    ***WAREMTAE***
  • Dr. Spec
    Dr. Spec Posts: 3,780
    edited April 2004
    Just catching up, here. Wow! Great looking blend. Fixing that mild dip will be as easy as upping the low pass to 45 Hz.
    Remember, the 40 Hz setting will already be down a few dB at 40 Hz, so you need to account for that. The combination of both the SVS and the Athena will sum to unity.
    I don't see any phase issues whatsoever. If you had cancellation, you'd see it in the form of an obvious null. Try 180 as a test and you'll probably see what I mean.
    Well you're getting a rising response to 25 Hz, as advertised for that model. Back to baseline at 22 Hz - nice. If you aren't blasting at max volume, definitely plug a port and drop the switch to 20 Hz and enjoy infrasonic extension.
    The most important part of this entire thread, though: "I love this thing". :cool:
    SVS
  • steveinaz
    edited April 2004
    Thanks to all for helping with this sub setup, I really appreciate the assistance. We've got some seriously knowledgeable people around here!
    Tonight I'll bump the XO to 45Hz and plot, I'll post the results here. My Athena's sound like their 12' tall....incredible.
  • I-SIG
    I-SIG Posts: 2,243
    edited April 2004
    Looks like my RS SPL meter was the ticket for ya! Good deal. I can't wait to check it out Sat!
    Wes
    Link: http://polkarmy.com/forums
    Sony 75" Bravia 4K | Polk Audio SDA-SRS's (w/RDO's & Vampire Posts) + SVS PC+ 25-31 | AudioQuest Granite (mids) + BWA Silver (highs) | Cary Audio CAD-200 | Signal Cable Silver Resolution XLR's | Rotel Michi P5 | Signal Cable Silver Resolution XLR's | Cambridge Audio azur 840C--Wadia 170i + iPod jammed w/ lossless audio--Oppo 970 | Pure|AV PF31d
  • steveinaz
    edited April 2004
    YES. Thanks bud for the loan. I've got to buy one soon. Saturday it is, again bring any music you want--we'll try to get more listen on this time and less drinking! LMAO!! I moved the XM tuner out to the patio system, just don't like the rolled-off highs and digital artifacts that thing has..XM NEEDS IMPROVEMENT!
  • Dr. Spec
    edited April 2004
    First up the low pass to 45 Hz and replot.
    If the results look good, then take the next step, plug a port, drop the tune switch to 20 Hz.
    I'm betting the resulting curve will show a bit less room gain, and an extended response down to about 18 Hz.
    SVS
  • steveinaz
    edited April 2004
    Will do Doc. Plot will be posted this evening. I'll give the 20Hz tune a try and see how it plots as well.
  • nebborjk
    nebborjk Posts: 425
    edited April 2004
    What are you using to generate the test tones?
  • gatemplin
    edited April 2004
    Nebborjk,
    you can get test tones here:
    http://www.snapbug.ws/bfd.htm
    Graham
  • nebborjk
    nebborjk Posts: 425
    edited April 2004
    Thanks gatemplin.
    Do you run those files as mp3 or convert to .wav or does it not matter?
  • gatemplin
    edited April 2004
    I havent tried those ones, but I dont think it matters if you leave them as MP3 or convert to wav.
    Graham
  • steveinaz
    edited April 2004
    That's the tones I used, but only the 18-100Hz. I left them MP3 as my DVD will play them (CD won't).
  • gatemplin
    edited April 2004
    How do you save those onto your computer? I just tried and cant figure them **** out. I assumed I knew how.
    Graham
  • steveinaz
    edited April 2004
    40/45 Hz crossover:
  • Dr. Spec
    edited April 2004
    Interesting. You lost a bit at around 30 Hz and it didn't help much at 45 Hz (maybe just a tad). I'd try phase tweaking next (as mentioned earlier by others), just to be sure.
    I'd only run 25-50 Hz to save time and just do a quickie plot at maybe 45, 90, 135, and 180 and see how it looks.
    My old 20-39PC+ actually worked best at 180 in my room; it's certainly worth a try tweaking the phase - it often pays dividends.
    Overall, most would kill for either FR. The 45 Hz setting is actually like +/- 4 dB from 100 to 22 Hz. Pretty amazing, really.
    SVS
  • steveinaz
    edited April 2004
    50Hz XO is flatter still! I'm wore out posting graphs, but 50 is just a tad flatter than 45Hz, especially in the 35-40-45Hz zone. Hmmm..
  • steveinaz
    edited April 2004
    Here's a graph with the following settings:
    XO=50Hz
    Phase=0
    Level=3
    Filter=25Hz
  • gatemplin
    edited April 2004
    That is very flat, you're lucky. I had a deafening 15 dB spike at 35-40 Hz before I got a PEQ.
    Graham
