Flac Files
gce
I want to try Flac files from my laptop to my AVR. The AVR will play Flac files but I need some kind of sharing software via DLNA on my laptop. I did download the codec for WMP and now WMP will play Flac files but the AVR will not. I'm new to this and want to hear what Flac files sound like. I got some sample files from HDtracks.
Can anyone point me in the right direction and/or tell me what software I need. I'm running Windows 7.
Anaheim Hills CA,
Post edited by gce on
Anyone?Anaheim Hills CA,
2 Channel: Rogue RP-5 / WireWorld Electra power cord / Marantz TT-15S1/ Ortofon - Quintet Black MC / Marantz NA8005 DAC / W4S mAmp's / Synology DS 216+ll-4TB / Polkaudio LSiM703 -
Links below are some of the most popular when ripping your cd's to your PC
http://www.dbpoweramp.com/
http://www.jriver.com/audio.html
http://www.mediamonkey.com/information/free/
This site has info
http://www.computeraudiophile.com/2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
You merely need to turn on DLNA and point your AVR to your laptop's DLNA server. This should get you pointed in the right direction:
http://www2.panasonic.com/webapp/wcs/stores/servlet/vSupportHowToGuideDetail?storeId=15001&idval=UCM_STG_CNT_051244&catname=Blu-ray+Disc%26%238482%3B+Players&title=Usage+Guide+-++How+to+Setup+DLNA+on+Windows+7+Operating+System&cm_sp=DMP-BDT310-Support+HowToGuide-_-Middle-_-Usage+Guide+-++How+to+Setup+DLNA+on+Windows+7+Operating+System
Monster AVL-300, HTS-2500 MKII -
Thanks for your reply but I still can't get this working. Went thru all the steps for DLNA server and the AVR sees the Flac file but when I push play it says Unable to play on my Yamaha AVR. I really want to hear what these sound like but its really frustrating trying to figure this out! :mad:Anaheim Hills CA,
TVersity will work with Onkyo, Pioneer, and Denon receivers I've used. Logitech Media Server works w/ my Pio. I'd go with one of those 2 setups before futzing w/ anything native to Windows 7.Dali Optikon 1Mk2
NAD D3020 V2
Schiit Bifrost 2/64
..the rest are headphone setups. -
Thanks PrazVT, I'll try that. I think if I understood what was needed I might be able to fix this. I mean the AVR will play mp3's, the computer will play mp3's and send them to the AVR and play them. So whats different with Flac's. What else is needed besides being able to play on a PC, send to an AVR and play on the AVR? Everything my mp3's and flac's do are the same except flac's won't play on the AVR.Anaheim Hills CA,
Finally figured this out. I'm using Asset UPnP and it seems to be working perfectly. :cool:Anaheim Hills CA,
