Flac Files
gce
gce Posts: 2,158
edited April 2012 in Music & Movies
I want to try Flac files from my laptop to my AVR. The AVR will play Flac files but I need some kind of sharing software via DLNA on my laptop. I did download the codec for WMP and now WMP will play Flac files but the AVR will not. I'm new to this and want to hear what Flac files sound like. I got some sample files from HDtracks.
Can anyone point me in the right direction and/or tell me what software I need. I'm running Windows 7.
Anaheim Hills CA,
Post edited by gce on
  • gce
    gce Posts: 2,158
    edited April 2012
    Anyone?
    Anaheim Hills CA,
    txcoastal1 Posts: 13,519
    edited April 2012
    Links below are some of the most popular when ripping your cd's to your PC
    http://www.dbpoweramp.com/
    http://www.jriver.com/audio.html
    http://www.mediamonkey.com/information/free/
    This site has info
    http://www.computeraudiophile.com/
  • Syndil
    Syndil Posts: 1,582
    edited April 2012
  • gce
    gce Posts: 2,158
    edited April 2012
    Thanks for your reply but I still can't get this working. Went thru all the steps for DLNA server and the AVR sees the Flac file but when I push play it says Unable to play on my Yamaha AVR. I really want to hear what these sound like but its really frustrating trying to figure this out! :mad:
    Anaheim Hills CA,
  • PrazVT
    PrazVT Posts: 1,607
    edited April 2012
    TVersity will work with Onkyo, Pioneer, and Denon receivers I've used. Logitech Media Server works w/ my Pio. I'd go with one of those 2 setups before futzing w/ anything native to Windows 7.
    Dali Optikon 1Mk2
    NAD D3020 V2
    Schiit Bifrost 2/64
    ..the rest are headphone setups.
  • gce
    gce Posts: 2,158
    edited April 2012
    Thanks PrazVT, I'll try that. I think if I understood what was needed I might be able to fix this. I mean the AVR will play mp3's, the computer will play mp3's and send them to the AVR and play them. So whats different with Flac's. What else is needed besides being able to play on a PC, send to an AVR and play on the AVR? Everything my mp3's and flac's do are the same except flac's won't play on the AVR.
    Anaheim Hills CA,
  • gce
    gce Posts: 2,158
    edited April 2012
    Finally figured this out. I'm using Asset UPnP and it seems to be working perfectly. :cool:
    Anaheim Hills CA,
