Good hard-sided luggage, any advice?
steveinaz
steveinaz Posts: 19,546
edited April 2012 in The Clubhouse
I'm looking for some hard-sided luggage that is more secure, any advice on good brands? I'm done with this soft-sided/zippered stuff....
Post edited by steveinaz on
  • thsmith
    thsmith Posts: 6,082
    edited April 2012
    Costco and or Samsclub has some that even come with TSA approved locks. Cant remeber the name
  • Syndil
    Syndil Posts: 1,582
    edited April 2012
    If you travel a lot, just get some cheap stuff. In my experience, NOTHING holds up to the abuse of baggage handling for long. I've had some expensive stuff in the past, but I've determined that's just pissing money away. Now I just Protocol crap from JCPenney. Of the expensive stuff I used to have, I've still got a single Lands End piece that hasn't fallen apart yet--but it will, just like the rest of the set it came from.
  • halo71
    halo71 Posts: 4,640
    edited April 2012
    "Mary Swanson.......ohhh Samsonite, that's it.....Mary Samsonite...." :cheesygrin:
    --Gary--
  • steveinaz
    edited April 2012
    LOL! LLoyd Christmas.
  • Jstas
    Jstas Posts: 15,001
    edited April 2012
    Stay away from gorillas.
    Expert Moron Extraordinaire
  • steveinaz
    edited April 2012
    My concern is that I typically fly with a firearm in my checked baggage, and although the firearm is in a locked case, I don't have a lot of confidence in the typical zippered type soft-side bag. I guess I could go with a heavy-duty soft type bag, but it would need very high quality zippers.
  • thsmith
    edited April 2012
    Steve, my inlaws fly alot and have the the Heys I think it is since that is waht is carried at samsclub or costco. They seem to like them.
  • Syndil
    Syndil Posts: 1,582
    edited April 2012
    If someone wants in your luggage, they're going to get in regardless. The TSA will only allow TSA-approved locks, and any would-be thief is guaranteed to have a TSA key. Most of them are easily broken without a key anyway. Really quite pointless. If you really want the thieves to stay out, don't lock it at all. A suitcase not worth locking is a suitcase not worth opening.
  • obieone
    obieone Posts: 5,077
    edited April 2012
    For F/A's, Pelican seems to be top shelf.
  • steveinaz
    edited April 2012
    I've got the FA locked in a small pelican, which then goes in the baggage (handgun).
  • steveinaz
    edited April 2012
    Syndil wrote: »
    Theft is not the issue, someone wants to steal it, they will---I don't want the gun to fall out of the bag under rough handling. Most zippers aren't confidence inspiring.
  • thsmith
    edited April 2012
    Steve, just checked with my father inlaw and it is the Heys hard side bags. Again, they travel extensively.
  • gdb
    gdb Posts: 6,012
    edited April 2012
    I saw a bunch of them at Goodwill for 2 or 3 bucks apiece. I bought a big Am. Tourister with the intention of lining it with dense foam rubber and shipping amps to the Left Coast in it.:wink:
  • Syndil
    Syndil Posts: 1,582
    edited April 2012
    steveinaz wrote: »
    Oh I gotcha. I've had things like handles and wheels fall off, but I've never had one open up on me accidentally. Actually now that I think back, I have, when I was a kid traveling with my parents. And it was a hard-sided case. Had those flat sliding clasps on it. The problem with it was that if it was handled roughly enough to cause the sides to deform, they would sort of bow outward at the edges, which was more than the clasp could take. It was one like these:
    http://www.ebay.com/itm/Vintage-Olive-Green-2-piece-set-Luggage-Suitcase-24x18x7-Clean-w-stains-inside-/230692896873
    But I would imagine (or hope) that they don't make crap like that any more.
    A lot of the hard-sided luggage you see nowadays uses zippers. That Heys brand that thsmith mentioned does. Anyway, good luck with your search.
  • dorokusai
    dorokusai Posts: 25,640
    edited April 2012
    I've been a long time Samsonite fan and have been very happy with my outlet model Ascella(sp?). It's a rigid, planished cover, roller bladed wheel model that I couldn't be happier with. They make an even more hardcore model but I couldn't justify the price increase. My wife likes the soft sided series since they expand with a zipper but I pack differently, so there you go.
    Another heavy traveler I know, Brett22 has recommended a brand I'm not familiar with, so I'll drop him a line or ask him when he comes into town on Friday. I'm with you Steve as I dislike soft-sided luggage for checked gear. I carry small bags with me but want all the protection possible when its getting manhandled underneath.
  • steveinaz
    edited April 2012
    Cool, thanks Mark.
    I'm seeing a number of samsonites that will do the job.
  • Gadabout
    Gadabout Posts: 1,072
    edited April 2012
    When flying I always travel with hard cases (usually when driving too). They just last longer. Let me agree with Mark about Samsonite. I have 3 Samsonite cases of varying sizes and couldn't be happier. Most of the Samsonite hard cases will have a lifetime guarantee. For discounts on Samsonite try outlet shops. I used to buy mine from the Denver factory outlet store but it is now closed.
    Also, the way to get a hard case to last is not to over stuff it. The hinge side takes a lot of force when doing this and will eventually give you problems. Another thing I look for is to make sure the case has rubber feet on the hinge side (or opposite the handle side). This way if you setting it down on it's side, it sits flat and doesn't scuff the case.
    Pelican is also the way to go for your traveling hand gun. It's what I put mine in.
    If you really want great stuff and price is no option look at Tumi. I have had otheir thier leather computer bags for the last 10 years. I always seem to choke when I lotheir thier luggage and it is around $600 a piece. Zero Haliburton stuff is really good but I have had a lock sheared on one of the cases I used to use for work (very large and used to ship UPS). While you mentioned you didn't want soft side luggage, I will say that TravelPro is a quality brand that will take a lot of abuse.
    I used to fly twice a month but now I usually drive most places and only fly 6 or 7 times a year. That being said, I'm traveling well over 6 months out of the year.
    Good luck in your search.
    Scott
    Without music to decorate it, time is just a bunch of boring production deadlines or dates by which bills must be paid. ..... Frank Zappa
  • steveinaz
    edited April 2012
    Appreciate the tips Scott.
  • gdb
    gdb Posts: 6,012
    edited April 2012
    Your name is very apropos, Mr. Gadabout !:smile:
