Which piece to run settings?
SDA1C
SDA1C Posts: 2,072
edited April 2012 in Electronics
I saw a thread on subs and though it odd I have been debating this same scenario in my 5.1
Which piece should I set my speaker distance/trim/gain on. The Oppo (source) or the TGIII (pre/pro) and regardless of which is the better choice where should I set the other?
Thanks folks, 1C
Too much **** to list....
Post edited by SDA1C on
  • thsmith
    thsmith Posts: 6,082
    edited April 2012
    Not sure I am following your question but I would do the speaker settings on the pre/pro. Not sure why you want to do anything on the source except standard stuff like PCM
  • tommyt21
    tommyt21 Posts: 685
    edited April 2012
    thsmith wrote: »
    Same not following Bit stream out of the Oppo then set it on the Pre/Pro.
    Living Room
    Fronts: RTi A7's
    Center: Csi A6 VR3 "Fortress Plus"
    Front Heights: Rti A1
    Surrounds: Rti A3
    Sub: HSU VTF-2 MK4 Damn this is a good SUB
    Pioneer Pioneer Elite: SC-35-> Emotiva XPA-3
    TV: Lg LW6500 55" Passive 3D
    Blu-Ray Panasonic BD 210
    XboX 360 Slim/Kinect
    Acoustimac red suede panels
    edited April 2012
    If your OPPO is connect by HDMI, then do all your settings in the receiver, the only setting in the oppo that would be relevant is the audio out setting. You have to tell it what to do with the audio. If you have the oppo connected by analog outputs, then use the settings in the oppo for speakers.
  • SDA1C
    SDA1C Posts: 2,072
    edited April 2012
    It is connected vis Toslink with hdmi audio off,. Bitstream-PCM 192k. I changed the distance around and don't really notice a huge difference there. If it has a bypass when the output is fixed I didn't notice it in the manual but that doesn't always mean much LOL?
    I just zeroed all the settings/distances/trims on the Oppo and set all speakers to small. I do notice a more defined surround effect. I think I'll tweak the Pre/Pro and see if can get anymore out of it.
  • SDA1C
    SDA1C Posts: 2,072
    edited April 2012
    tommyt21 wrote: »
    Just wanting to tweak and play. That's all.
    edited April 2012
    Not using it for video then ? If just connected by toslink, all your speaker settings should be done in the avr then, as most all speaker settings are done in the digital domain.
