Subwoofer Plate Amplifier
teamjhertz
teamjhertz Posts: 363
edited April 2012 in Wanted (WTB) Classifieds
I am looking for a subwoofer plate amplifier for a DIY project. I would prefer a OAudio, Apex Sr or non servo Rythmik amp.
Please let me know what you have. Thanks
Post edited by teamjhertz on
  • lanchile
    lanchile Posts: 560
    edited April 2012
    Build it better! just start from scratch...get a nice power supply and get an NXV200 from Aussie amplifiers. it will kill most of those commercial ones for sure! if you are good soldering and fallowing instructions...it will be done in no time!
    Make it simple...Make it better!
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited April 2012
    Why not use a pro amp? More power and cheaper cost. Which sub are you using?
  • teamjhertz
    edited April 2012
    I have a pair of GR Research SW12 subs. I was looking for amps that Danny recommend to use with them.
    The final load is 4 ohms and power handling is around 400 to 500 watts total.
    I will take a look at the DIY amp that was recommended
  • Conradicles
    Conradicles Posts: 6,343
    edited April 2012
    I have an older Apex Jr you can have for $35 shipped.
    It works great. Will post pictures if interested.
  • teamjhertz
    edited April 2012
    The Apex Jr is a little less wattage than I was looking for but the price is really cheap. Which version is it the C-6 or the discontinued one?
  • Conradicles
    edited April 2012
    teamjhertz wrote: »
    The discontinued one. I can't really find much info on the web. Maybe 100 watts into 8 ohms I think. Of couse 4 ohm stable. Originally had a remote control but the previous owner lost it. It is a bit scratched up but works great and is dead quiet.
  • rooftop59
    rooftop59 Posts: 8,121
    edited April 2012
    If the op passes I'll take it. Let me know.
    Game Room 5.1.4:
    Bedroom 2.1
  • teamjhertz
    edited April 2012
    Thanks for the additional information. I am going to have to pass on it at this time.
    Please offer it up to Rooftop59
  • rooftop59
    edited April 2012
    payment sent. Thx!
    Game Room 5.1.4:
    Bedroom 2.1
  • 20hz
    20hz Posts: 636
    edited April 2012
    I gotta a great deal on a Dayton sa240 at parts express $108 new 240 watts@4 ohms it has variable crossover points and volume levels , it easily drives my 15" quatro , its a A/B class amp has the big heat sincs , I wanted a Dclass but the salesman said I would be happier with the sa240 they last longer and repairs are easy whereas a dead Dclass is usually garbage .
    Parts express sells "scratch and dent" stuff on ebay for about 25% less than list .
    teamjhertz wrote: »
  • teamjhertz
    edited April 2012
    Thanks for the heads up on this amp I will keep an eye out for a deal.
