what are DQ-10's worth
faster100
faster100 Posts: 6,124
edited April 2004 in Speakers
what are DQ-10's worth? I might have some inline today.. only don't know if they work yet.. But the price is damm right!!! FREE
Thank you,
MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
LSIfx surround backs
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Rotel 1080 stereo amp
Polk sda 2B
kenwood grunt Tuner
realistic lab 450 TT
Signal cable IC
Post edited by faster100 on
  • faster100
    edited April 2004
    well i picked them up.. They do work.. the woofs need refoaming.. I may be taking them tonight for the refoam job, 29 bucks each sound ok for a refoam of a old advent 10"?? I will post pictures later after i clean them up..
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
  • Ceruleance
    Ceruleance Posts: 991
    edited April 2004
    I thought the going rate was more like $20, but if it's quality work from someone you trust then by all means.
  • RuSsMaN
    RuSsMaN Posts: 17,985
    edited April 2004
    It's actually a 9.5 inch woofer, in a 12" basket with a fiberboard ring.
    $30 a woof isn't robbery, assuming everything works, and they are clean (or you clean them up), they can bring $250-$400 / pair - depending of course if someone in your area is looking for them.
    Cheers,
    Russ
  • faster100
    edited April 2004
    so i assume these are pick up only type sales.. I want to sell them.. I have the grills and everything, the tweets and mid works great, i disconected the woofer and am taking it to speaker world locally.. The guy sounds real knowledgable and knew what speakers these were, when about they were made and said he had the foam and parts if they needed fixing.. Im gonna clean the speakers, dust off and the cloth wiped. the cross over is covered in dust.. The woofs should be done thursday he said.. I will post cleaned pictures later tonight... Thanks for the info.. These have brown sides and black grill cloth, and a metal grill to cover the back guts
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
    F1nut Posts: 51,999
    edited April 2004
    Do you have the stands?
  • RuSsMaN
    edited April 2004
    No one ever has the stands Jesse, come on.
    F1nut Posts: 51,999
    edited April 2004
    That's right Russ, that's why I asked because if he did then they would be worth MO money. :D
  • dragon1952
    dragon1952 Posts: 4,914
    edited April 2004
    It would probably cost close to 30 bucks for the refoam kit anyway so 60 bucks isn't too bad. They are REALLY easy to refoam though.....I just did an 8" Advent (my first attempt at this)and it was very easy.
  • faster100
    edited April 2004
    well this guy gives 10% discount if you pay at dropoff.. He said they looked Real nice.. we actually started talking audio.. he/they actually design and build custom speakers in house.. on a small scale.. custom veneer to match.. nice work.. me and another customer and him were chatting and listening to a pair of his designed speakers... Nice guy and knows alot from the short time speaking with him... So it was 54.00 for the refoam.... knew alot about the Dq 10's... im gonna clean them shortly here..
    No stands.. but i May purchase a pair i seen today to make them worth more..
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
  • faster100
    edited April 2004
    pics, semi cleaned... lots left
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
  • faster100
    edited April 2004
    and
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
  • faster100
    edited April 2004
    The woofers are missing as they are at the shop.. will post cleaned and assembled pics later this week
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
  • George Grand
    George Grand Posts: 12,256
    edited April 2004
    Not taking the way they sound into account, those things are butt freakin' ugly man.
    George Grand (of the Jersey Grands)
  • dorokusai
    dorokusai Posts: 25,576
    edited April 2004
    I completely agree....ugly as a pair of blue twinkies during a yeast infection.
  • RuSsMaN
    edited April 2004
    For what you've got in 'em, I'd put the smart money on keeping them for a 2ch rig.
    Not knocking your current gear, but they are lightyears ahead of the other speakers you own.
    Cheers,
    Russ
    F1nut Posts: 51,999
    edited April 2004
    Agreed, run them with a sub and you've got a killer 2 channel rig.
  • faster100
    edited April 2004
    they need cleaning more.. they really do look good in person imo..
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
  • faster100
    edited April 2004
    you guys really think thier ugly? :D The camera brings out the dust big time. Im going to clean them some more tomorrow.. Glue back the grill cloth on the bottoms. and tuner cleaner the crossover after i get some.. I already old englished the wood panels so they look nice now... after i get the refoamed woofs.. i plan to demo them and enjoy their unique sound... But they are to big for my small florida room.. 2 channel rig room.. They will be resold on e-bay, eventually... A neighbor was gonna toss them out and i intervened and asked for them, I got them free and now am getting the woofs refoamed for the resale.. Otherwise i would part them out.. which i don't want to do.. and wont
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
  • HBombToo
    HBombToo Posts: 5,256
    edited April 2004
    Don't forget the Armour All:D
    HBomb
    ***WAREMTAE***
  • faster100
    edited April 2004
    Nah, i wouldn't think of it... actually i have cleaned so many items for resale.. ive kinda got a knack for making things look nice.. or restored, Armor all however has its place when trying to replenish old rubber, Just not speakers:)
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
  • dorokusai
    edited April 2004
    This isn't a speaker that you "part out", because it won't get you much money anyways....but beings you paid nothing, I guess it's moot.
    You should just throw them in the trash, like your neighbor.....because you have no idea what the heritage, or history is on that speaker.
    Not every piece of gear, and/or great deal that finds oneself is meant for immediate Ebay auction.
    Have fun with them, good luck.
  • faster100
    edited April 2004
    Oh get over it!! My bread my friend is buying and selling.. I would part it out if they werent in such good shape period..
    I will sell these speakers and buy my wife her Anniversary gift ive been saving for, It means more to me then some older speakers that you guys deem priceless.. it wasnt my "neighbor friend".. It was a few streets up if you want/ need to know the facts/// I came across them after a bike ride with my kids... I asked if they were trash and they said yes, take them.. I had to wait for my wife to come home with the truck to get them... and my mom stopped by so i used her car and picked them up, hence the time frame of me posting and actually getting them, Im putting almost 60 bucks into them to make some money for other things... I truely would consider keeping them if i had the room, Ask spastic how small my Fla. room is and house for that matter.. no room for DQ-10's... I already stated i wouldnt part them out... Sorry for posting to the speaker god and not pleaseing you with my plans :rolleyes:
    My my how things don't change around here...
    edit: what Mark, your time to start rideing my **** now?? Everyone else has seemed to be pretty good lately, I guess all good things must end eh!
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
  • faster100
    edited April 2004
    FWIW, here they are all cleaned up
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
  • faster100
    edited April 2004
    and
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
  • faster100
    edited April 2004
    and lastly
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
  • faster100
    edited April 2004
    one more
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
