LSi Tweeter Replacement
mraub
mraub Posts: 3
edited April 2012 in Troubleshooting
I fear I have blown a tweeter on one of my LSi 9's. I know the LSi's use the Vifa ring radiator, but does anyone know what model tweeter is used?
Thanks,
MIKE
Post edited by mraub on
  • Face
    Face Posts: 14,340
    edited April 2012
    FYI, Polk's tweeters are not an exact match of what you'd fine elsewhere.
    EndersShadow Posts: 17,723
    edited April 2012
    Mention you are a club polk member and you get 10 percent off and free shipping I believe...
    edited April 2012
    mraub wrote: »
    Thanks,
    MIKE
    Welcome Mike, contact CS, they'll take care of ya.
    Have you figured out why you blew a tweeter ? So it doesn't happen again. What other gear are you running ? Maybe take it easier on the volume dial. Limits my friend, everything has 'em.
    F1nut Posts: 52,009
    edited April 2012
    Might not even be the tweeter. There's a 5 watt resistor on the crossover that's prone to cooking....you should check that.
    edited April 2012
    Good point Jess, but I imagine he'll find that out soon enough if he swaps tweeters and the new one doesn't work.
