Good DDD music source..
steveinaz
steveinaz Posts: 19,546
edited April 2012 in Music & Movies
I have mentioned Lifescapes a number of times on many threads. Most if not all the recordings are DDD and from 24bit masters. I discovered these years ago at a local Target store, bought a few, and was hooked. Here's a link:
http://www.lifescapesmusic.com/CustomEditorial/HOME.aspx
Check'em out, the recordings are very good. I use some of them as reference "show off" music. Some of my favorites are:
Smooth Jazz
Relaxing jazz
Mexico
Imagine Santa Fe (native American type music)
They're especially nice as dinner background music, etc. Also check your local Target, usually by the greeting cards section.
Post edited by steveinaz on
  • rooftop59
    rooftop59 Posts: 8,120
    edited April 2012
    I just purchased the Mexico disc, really outstanding thanks for the recommendation.
    Game Room 5.1.4:
    Bedroom 2.1
  • steveinaz
    edited April 2012
    That's one of my favorites---that old upright string bass is wicked huh? These recordings are really quite good. You'd love "Smooth Jazz" as well.
  • rooftop59
    edited April 2012
    Yea the tone and texture of the bass is pretty outstanding, as is the clarity and separation of the instruments. I was thinkIng of getting one of the jazz ones next...
    Game Room 5.1.4:
    Bedroom 2.1
