Good DDD music source..
steveinaz
I have mentioned Lifescapes a number of times on many threads. Most if not all the recordings are DDD and from 24bit masters. I discovered these years ago at a local Target store, bought a few, and was hooked. Here's a link:
http://www.lifescapesmusic.com/CustomEditorial/HOME.aspx
Check'em out, the recordings are very good. I use some of them as reference "show off" music. Some of my favorites are:
Smooth Jazz
Relaxing jazz
Mexico
Imagine Santa Fe (native American type music)
They're especially nice as dinner background music, etc. Also check your local Target, usually by the greeting cards section.
Smooth Jazz
Relaxing jazz
Mexico
Post edited by steveinaz on
I just purchased the Mexico disc, really outstanding thanks for the recommendation.Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
That's one of my favorites---that old upright string bass is wicked huh? These recordings are really quite good. You'd love "Smooth Jazz" as well.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
Yea the tone and texture of the bass is pretty outstanding, as is the clarity and separation of the instruments. I was thinkIng of getting one of the jazz ones next...Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
