Parasound HCA-1500A
VR3
Now that my Super Towers are sold I do not need this much power - amps works great, very nice warm tone with great imaging... definitely a power house capable of driving very large speakers...
See below for specs -
Condition I would say is 7/10 - in normal lighting you do not see alot of the marks that show up in the picture...
Price - $450.00 SHIPPED WITH PAYPAL - BOMBO SHELTER PACKAGING
Designed by John Curl
THX certified by Lucasfilm Ltd.
Independent power supplies for each channel
Massive 1 kVA toroid power transformer
60,000 ?F computer-grade capacitors in power supply
Multiple polystyrene film bypass capacitors in power supply
DC Trigger Auto On Feature
Cascoded Class A input stages with matched J-FET pairs
Handpicked complementary MOSFET transistors in high voltage driver stage
8 complementary pairs of 15 ampere 50 MHz output transistors
Output transistors direct-coupled to speakers without LRC networks
DC servo direct-coupled audio circuits with 0.8 Hz rolloff
High-bias Class A/AB operation
Gold-plated metal structure RCA input jacks
Gold-plated looping output jacks
Multiple temperature sensors and silver-cadmium relay protection
Glass epoxy circuit boards, double-sided for precision
Custom designed audiophile-grade AC power cord
Multiple Protection Circuits
SPECIFICATIONS
Continuous Power Output - Stereo:
205 Watts RMS x 2, 20 Hz-20 kHz, 8 Ω, both channels driven
315 watts RMS x 2, 20 Hz - 20 kHz, 4 Ω, both channels driven
Continuous Power Output - Mono:
630 watts RMS, 20 Hz - 20 kHz, 8 Ω
Current Capacity:
60 amperes peak per channel
Slew Rate:
> 130 V/?second
Frequency Response:
5 Hz - 100 kHz, +0/-3 dB at 1 watt
Total Harmonic Distortion:
< 0.03% at full power; < 0.01 % typical levels
IM Distortion:
< 0.03 %
TIM:
unmeasurable
Dynamic Headroom:
> 1.5 dB
Interchannel Crosstalk:
> 80 dB at 1 kHz; > 60 dB at 20 kHz
Input Impedance:
33 k Ω
Input Sensitivity:
1 V for 28.28 V, THX Reference Level; 1.2 V for full output
S/N Ratio:
> 110 dB, input shorted, IHF A-weighted
Damping Factor:
> 800 at 20 Hz
Power Consumption:
500 watts
Dimensions:
w 19" x h 5 1/4" x d 16", h 5 7/8" with feet
Net Weight:
40 lb
SPECIFICATIONS
Current Capacity:
Slew Rate:
> 130 V/?second
Frequency Response:
IM Distortion:
< 0.03 %
TIM:
unmeasurable
Dynamic Headroom:
> 1.5 dB
Input Impedance:
33 k Ω
Input Sensitivity:
S/N Ratio:
Damping Factor:
> 800 at 20 Hz
Power Consumption:
500 watts
Dimensions:
Net Weight:
40 lb
Post edited by VR3 on
Will go on Audiogon tomorrow.
Thanks!
- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
PM sent.
Replied- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Still available- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
bump- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Idle threat?Will go on Audiogon tomorrow.
Thanks!
bump
Somebody ought to snatch it up here, before he follows through on it... nice amp! -
I see that your old monos are up for sale again, Trey.HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
Where at???
I plan to put it on the Gon here soon - I hate Audiogon so I am trying to avoid it- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
LOL!!! Wow, us Audiophiles are NUTS!! lol
Those are great amplifiers, that is for sure- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Plenty of power for LSi-15s above! Plus I suspect with all the technical expertise that the V-man has that the amp is in "mint" condition. This is an excellent price for a nice, powerful, slightly warm and musical power amp! A top pick in its category.
Don't think! Buy!
Im considering this amp or an xpa2 for my two channel rig which is lsi15.
Plenty of power for the 15's.:biggrin:
This amp will sound better than the XPA. I've never heard the XPA-2, but I've heard an XPA-5 on LSi's, as well as a Parasound HCA-2200ii on the same LSi's, and the Parasound is more refined. No question for 2-channel music, if you ask me.
Office: Phone/Tablet > AudioEngine B1 > McIntosh D100 > Bryston 4B-ST > Polk Audio LSiM-703's -
Im considering this amp or an xpa2 for my two channel rig which is lsi15. Any thoughts on whether this is enough power for lsi15? I listen very loudly at ref levels. Want that Hca3500 but it is couple months old probably gone.
i recently had and sold an xpa-2 after acquiring a parasaound hca1200 mkll.
the parasound was a much better and musical amplifier and although rated for only 205 wpc it seemed more powerful than the xpa-2. i was using polk 3.1tl's with the amps. the emotiva left me cold and didnt have the soundstage or instrument clarity the parasound did, but that was in my set-up in my room, YMMV. BUT, I would never buy an xpa-2 again. -
pm sent
Amp is sold pending payment
Thanks- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Payment sent. Thank you
Great packing job. Thank you
Enjoy, I love my HCA-1500. I also like the preamp loop outputs on the back for subwoofer'in it up, 2 channel style.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
Wow, I can't believe it took that long to sell...
Enjoy the new amp! I love mine. -
TTT This is the amp that I purchased here and never used. Now I don't have to take any pictures.......
I am very confused...Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
I've had 2 polk members that have shown interest in purchasing this amp. I wanted to post the details for them.
+1 LOL, I was wondering where this thread was going, these are sweet amps, glwts on this!I am very confused...
Is it for sale? What price? Shipping? Lots of questions..
400.00 shipped but I have to come up with 2 boxes.
This is a very good price, someone needs to jump on this now.
I'm interested. How old is it? I was thinking of buying an Emotiva, but I've always wanted to try Parasound. I'm just concern about how long it will last and how much it will cost to fix if that happens.AVR: DENON X4000
FRONT L/R: ARX A3RX-C
CENTER: ARX A2RX-C
SURROUND L/R: ARX A3
SUBWOOFER: PSA-XV15
SERVER: UNRAID 15TB
MEDIA PLAYERS: DUNE SMART SERIES D1
HDTV: VIZIO M601D-A3R -
I am taking this off the market to sell locally . Too heavy to ship. Thanks
Totally understand . Even locally, someone should be willing to drive 100 miles to come and pick it up from you, I know I would.
