5.1 Polk Audio Need Amp or amps
Anton
Anton Posts: 3
What is the amp or amps needed to power and reveal the potential of this 5.1 set at 100%?
2x Polk Audio RTi A9 (front)
1x Polk Audio CSI A6 (center)
2x Polk Audio RTi A3 (back)
1X Polk audio PSW-505
Post edited by Anton on
  • PSOVLSK
    PSOVLSK Posts: 5,412
    edited April 2012
    What are you using as a pre? Budget?
    Searching for amps will make your head spin because there are so many choices. www.audiogon.com Check out Rotel, NAD, B&K, Emotiva, Parasound, Carver (Sunfire), etc.
  • BlueFox
    BlueFox Posts: 15,250
    edited April 2012
    100% what? Distortion?
    edited April 2012
    I think he means what receiver will power all that to it's full potential. Given that, whats the budget ? Maybe a Pioneer SC receiver, something with a beefy power supply if you don't want to add another amp. New or used ?
  • Anton
    Anton Posts: 3
    edited April 2012
    For any prices.Used or new doesnt matter for me.I write up - need something what can reveal the potential RTi A9
