Denon 3803 shuts down
  • Frank Z
    Frank Z Posts: 5,860
    edited April 2004
    The m-200's can be stacked on top of each other, according to the Outlaw site.
    The Outlaw amps have individual heat sinks for each amplifier channel and run fairly cool.
    Are all of the outlets in your room on the same breaker? Your receiver won't be drawing as much current since the internal amps will no longer be used. The only way to know for certain is to measure the total amp draw on that circuit. Keep in mind that just replacing the circuit breaker with a larger size is not recommended. A larger breaker will require a larger gauge wire. (20a circuit needs 12ga wire)
    Yes your electricity usage will increase with a new amp, so you will see a higher bill.
    The Monster amp is sweet! If I had the cash I'd love to add a few for all of my speakers. JRausch did tell me that a multichannel version was coming, but I don't know when that will happen.
    F1nut Posts: 51,709
    edited April 2004
    Dave,
    To answer your question about how far you can turn up the volume (even with a new amp) the general rule is no more than halfway.
  • dave shepard
    dave shepard Posts: 1,334
    edited April 2004
    Thanks for the info guys. I will be mauling it over until I'm ready to make that move and will I'm sure have more questions when the time comes.
    Thanks again
    Dave
