Seriously considering this purchase
  • cstmar01
    cstmar01 Posts: 4,424
    edited April 2012
    I would really like to hear a XA series amp sometime.
    Still haven't heard a full Pass system and will need to do that in the future.
    Does pass have any SIT amps out right now? I saw the XS (I think is the series name) but retail at like 85K nothing that anyone around my area will have for a long time.
    heiney9 Posts: 25,501
    edited April 2012
    There is a stereo and mono version of the SIT amps but they are only about 10wpc currently.
    http://www.audioaficionado.org/general-audio-discussion/11127-nelson-pass-firstwatt-sit-1-nearing-completion-6moons-com.html
    http://www.firstwatt.com/pdf/prod_sit1_man.pdf
    Once again (see above) Nelson commentary in the owners manual is as informative and in depth as ever.
  • drumminman
    drumminman Posts: 3,396
    edited April 2012
    madmax wrote: »
    Yes, the original AI-1 and one I made using a transformer polk recommended at the time. Not the best results for me with either one. I think DK's used a very fine torroid transformer, probably much better.
    Hey MM, you ought to give the AI-1 another chance using Darqueknight's recipe. I built the first version with the 800VA transformer, and the improvement is easy to hear. It also gets even better with burn in. And this is with a common ground amp.
