how to hang up fxi a6
Hello everyone
How far to hang the speaker from the floor.
Is close to the ceiling?
Or
1.5 from the floor?
Salon size: 4 * 5 meters
When one wall is open to the kitchen.
Please refer to two situations:
1) When the sofa back against the wall
2) When the sofa away from the wall at 50 cm
What is the standard mean?:eek:
And how about you?
Thank you very much
Or
1.5 from the floor?
And how about you?
Thank you very much
Post edited by SHLOMIS1Z on
I have my FXiA6's at 2ft (0.6096m) above seated ear level. My sofa is on the back wall.Anaheim Hills CA,
2 Channel: Rogue RP-5 / WireWorld Electra power cord / Marantz TT-15S1/ Ortofon - Quintet Black MC / Marantz NA8005 DAC / W4S mAmp's / Synology DS 216+ll-4TB / Polkaudio LSiM703 -
Why no precise formula for the dimensions
thanks a lot.....
Because, particularly with those bi-directional speakers, there's no need or advantage to precision placement. Here's some reading for you:Why no precise formula for the dimensions
http://www.polkaudio.com/education/showanswer.php?question_num=78
http://www.polkaudio.com/education/showanswer.php?question_num=45
http://www.polkaudio.com/education/article.php?id=15 -
Go to www.dolby.com and learn where surround speakers are suppose to be placed. Then adjust as close as possible for your room seating.Why no precise formula for the dimensions
I have found that hanging surround speakers at 72 inches from the floor to the tweeter works best in all rooms. If you have to go higher then that try to stay as close to 72 as possible. Lower sucks and higher can echo in some rooms.
Also check out www.thx.com and www.dts.comDan
thanks alot mu frend's :cheesygrin:
