decent cheap HT pre-amp/processor
pitdogg2
My lovely Yamaha rxv992's pre-outs have went out. The cost to fix is WAY more than I'd like to spend.
Anyone have a cheap Home Theater pre/pro that preferably has component inputs? Looking to spend less than 150 with shipping included
PM me if you need to find something a good home that will be well taken care of.
Ivan
Ivan
Post edited by pitdogg2 on
i have a sunfire cinema grand. can't remember if it has the component inputs that your looking for though. otherwise i have a couple receivers also one is a yamaha and the other is a denon. also where in illinois are you located?
Does sunfire cinema grand and the words "cheap" and "less than 150" go together?
--Gary--
i knew that wasn't right its a theater grand not a cinema grand.
If it does I'm all over it well as long as component video input's that will go well with my TFM25 -
Just wanted to thank Andy for the Denon 3805. Nice day to drive to Rockford and pleasant conversation.
Thanks again Andy everything works great.
