Corrected sweep...how's this?
steveinaz
Athena AS-F2 from listening position, corrected 18-100Hz:
Post edited by steveinaz on
The spl at ~20Hz is amazing...
After seeing the curve where do you think you will cross? I'm thinking 45 might be a little low???
HBomb***WAREMTAE*** -
I'm thinking 50Hz will be my starting point, then I'll plot the system together and see how it looks...
That 20Hz tone is pretty incredible, the cones were "swimming" in the cabinet..LOL! I was impressed with how clean the tone played thru.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2 -
Looks like a nice curve.
I'd probably opt for about 45 Hz to start. Remember, the low pass filter on the SVS is 2nd order, and most filters are designed to already be a few dB down at the filter point.
The Athena is also down a few dB at 45 Hz, so the two outputs will sum.
It might be hard to get a perfect transition, but I don't think it will look bad at all; that's not a hard curve to work with at the low end.
Also, don't be fooled by the 70 dB SPL at 20 Hz - the sound pressure only tells you half the story. Harmonic distortion is responsible for a large portion of that reading. In fact I'm sure Steve could clearly hear the 2nd order harmonic, which would be 40 Hz.
Doc"What we do in life echoes in eternity"
SVS -
Doc
This never even occurred to me... very interesting indeed and it makes perfect sense to me now.
HBomb***WAREMTAE***
