A big thanks to Bigaudiofanatic
Serendipity
So today I decided to install speakers in my new Nissan Versa. Unfortunately, I was having difficulties pulling the door panels off. I emailed Bigaudiofanatic and within a short period of time he told me to check the screws under the door handle covers, or one of two hidden screws. I got the door panels off in no time and would like to thank him for helping me get this done! Otherwise, I would have had to take the car to a car audio install shop. He was very helpful and got me the info I needed ASAP!!
Here are pics of the install:
polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
Front projection, 2 channel, car audio... life is good!
Here is the speaker I installed in the opening. It's a Nissan OEM, fit perfectly!
Again thanks Bigaudiofanatic!polkaudio RT35 Bookshelves
Your welcome man! Any pics of the speakers.
Anyone ever need info please feel free to pm, email or come to my website.
www.bigaudiofanatic.comHT setup
Panasonic 50" TH-50PZ80U
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
MIT Exp 3 Speaker Wire
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
63 inch Samsung PN63C800YF
Polk Surroundbar 3000
Samsung BD-C7900 -
I used OEM Nissan speakers. Fit the factory openings perfectly and very easy to install! Ran 16AWG speaker wire to the doors and drilled a hole in the weatherproofing thing by the door hinges. Sounds like a stock system should and works great! Made sure to leave enough slack in the wire so the doors could be opened and closed fully. I am very happy with how everything turned out.
Only problem was I broke 2 plastic fasteners...polkaudio RT35 Bookshelves
