Funky Sony speakers from a GS
Don't sound half bad!
HT:
Martin Logan Motion 40
Martin Logan Motion 50XT
Emotiva Airmotiv E2
SVS SB16 Ultra
Def Tech Reference Sub
Yamaha RX-A3070
Signal Cable speaker wires & interconnects.
Emotiva Airmotiv E2
SVS SB16 Ultra
Yamaha RX-A3070
Post edited by gwh on
They didn't sound half good either...The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
nooshinjohn wrote: »They didn't sound half good either...
Not even 50% good?:biggrin:If you can't hear a difference, don't waste your money. -
There were others that made speakers with like drivers. Technics comes to mind in that period. Mid '80s maybe?
Technics SB-M1
Those don't look anything like the Sonys. What are your smokin' dude? Don't hide it,let's divide it !!!!If you can't hear a difference, don't waste your money.
OK,
How about these (same time period)?
Minimus 35s
I am always a glass half full kind of guy, but in this case I would make an exception. As I recall, the Sonys were a part of a rack system, and they were built as cheaply as could be done.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
OK,
Minimus 35s
cnh
Closer, your buzz must be wearing off !!!!If you can't hear a difference, don't waste your money.
