Alternative to discontinued RS SPL meter....
steveinaz
Specs out slightly better than the RS meter. Freq range: 31.5Hz-8kHz ("C" weighting). I haven't found a meter that goes lower in freq at a reasonable cost. $69. This is a re-badged $179 Extech meter. As far as error factors for lower freq's, I don't know if RS SPL numbers would be compatible.
http://www.amazon.com/American-Recorder-Technologies-SPL-8810-Pressure/dp/B000I4ZVHU/ref=pd_cp_hi_1
Steve, if you haven't bought that yet, you may have not seen this...
http://www.ebay.com/itm/NEW-Radio-Shack-33-2050-Sound-Level-Meter-Analog-SPL-Sound-Pressure-Level-/251021407456?pt=LH_DefaultDomain_0&hash=item3a720ab4e0
I guess what your saying is that your looking for a more accurate meter at lower freq's? -
Thats why I use REW as they have a correction file for the RS Meter. The Beringer mic is suppose to be good and REW has a calibration file for it too.
Just a thought.Speakers: SDA-1C (most all the goodies)
I was just looking for an alternative, thought I'd share. I took a look at REW, was little too complex for my pea brain. I already ordered the meter above.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
I'm with you on that! -
Bought a couple analog RS meters when they had them on sale at radio shack for $13.
I had one some years ago, but when I get rid of my first sub--I sold it to Cathy.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
I was just looking for an alternative, thought I'd share. I took a look at REW, was little too complex for my pea brain. I already ordered the meter above.I'm with you on that!
If I figured it out anyone can. Not sure how you are taking measurements but trust me, if you can invest 30 mins effort you will never look back.Speakers: SDA-1C (most all the goodies)
Does your laptop have to have a good soundcard and stuff like that? My laptop is about as basic as they get.
I'm integrating a PB12-NSD (sledgehammer version) into a strictly 2-channel system via line level connections to the sub (using the sub crossover). So I was gonna do the traditional frequency sweeps to verify crossover freq and level. The mains are Harbeth 7ES-3's, which will be run full range.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2 -
You have to have an external sound card device for most laptops and REW, I bought the soundblaster live 5.0 off the bay for something like 25/shipped. I fooled around with it for a few days, got frustrated, and bought a SMS-1.
Most laptops dont have true MIC in so you would need an external SC. If you are serious I will ship you mine and RS analog SPL.Speakers: SDA-1C (most all the goodies)
I appreciate the offer, seriously--but let me give the 'ol spl meter a try first and see if I get satisfactory results. I think my laptop does have a mic input, I'll have to check it tonight.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
If using the RS analog SPL you will need the correction table to do it accurately.
http://forum.audiogon.com/cgi-bin/fr.pl?htech&983682086&openflup&1&4Speakers: SDA-1C (most all the goodies)
And I still have it Steve!Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
Received the new meter, looks real nice--easy to use. Still don't know if lower freq compensation would be needed. Research on the net has turned up nada.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
I have had that same SPL meter in my shopping basket at Amazon for a couple of weeks now and from what I have been able to find it is a good meter and a very good price, although I'm still looking around. I hope I can make a decision before they are all gone.Main Family Room: Sony 46 LCD, Sony Blue Ray, Sony DVD/VCR combo,Onkyo TXNR 708, Parasound 5250,
Living Room: Belkin PF60, Parasound HCA2200, MIT ProlineEXP balanced IC's,Emotiva XDA-1 DAC/Pre,Emotiva ERC2 transport,MIT AVT2, Polk LSI 9's. -
I'm not concerned if it's accuracy only applies to the specified range of 31.5Hz-8kHz, as I'm mostly interested in the measurements at the cross over point (50Hz for my setup). It's very nice quality and actually ships with a battery! It also has a threaded insert for use with a tripod.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
Steve, head over to hometheatershack.com and ask those guys about the meter and comp files.Speakers: SDA-1C (most all the goodies)
10-4 good buddy.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
They are a good group and know REW like the back of their hand. Have not been there in a few years but I bet it has not changed.Speakers: SDA-1C (most all the goodies)
