Saw these really powerful tube mono's on Ebay
polkfarmboy
polkfarmboy Posts: 5,703
edited March 2012 in 2 Channel Audio
DOGE 9 Hi-End Tube Monoblocks Pair
Here is a link and check out the power rating for each http://cgi.ebay.com/DOGE-9-Hi-End-Tube-Monoblocks-Pair-Brand-New-/350281352071#ht_1163wt_1048
Maximum Output Without Distortion: 180W
●Sensitivity (Output @ 150W): 2V
●Frequency Response (Output @ 150W):
20Hz-20KHz+/-0.5dB
●THD (1KHz/150W): <= 0.3%
(1KHz/100W): <= 0.15%
(20Hz-20KHz/50W): <= 0.3%
●S/N: Main Channel: >=90 dB
●Input Impedance: 50 KOhms
●Output Impedance: 4, 8Ohms
●Inputs: RCA x1
●Maximum Power Consumption: 450W
●Power Supply: AC230V/50Hz (or AC110V/60Hz, for 110V version, please check with us before you buy it!!!)
●Gross Weight: 52 Kgs
●Size: 500 x 430 x310mm.
I will be chasing some monoblocks to feed a really hungry pair of ML Vista and wonder if these should make the list
Post edited by polkfarmboy on
  • Joe08867
    Joe08867 Posts: 3,919
    edited March 2012
    I've heard good things about Doge, I have no personal experience with them though.
    Looks good, I would change the tubes probably.
  • SDA1C
    SDA1C Posts: 2,072
    edited March 2012
    I have never felt comfortable buying anything that labels it's self "High End". Just my .02
    Too much **** to list....
  • inspiredsports
    inspiredsports Posts: 5,502
    edited March 2012
    I just can't fathom sending $3K for audio gear to a vendor shipping from "China, China".
    Conrad Johnson PV-5 w/mods
    MF x-DAC V8, HAInfo NG27
    NAD SS rigs w/mods
    GIK panels
    heiney9 Posts: 25,612
    edited March 2012
  • inspiredsports
    edited March 2012
    Yep, and folks also rave about Bose, Emo and Monster and I don't send money there either.
    NAD SS rigs w/mods
    GIK panels
  • SDA1C
    SDA1C Posts: 2,072
    edited March 2012
    Honestly I think H9 Is pointing out that there are limited responses even on Agon... sort of tells the tale I would think.
    edited March 2012
    Just pointed a link to some info, that's all. Not endorsing or diss'ing said product. I will add you'd be nuts to send $3K to China for those amps. You could do better here in the states for that kind of money.
    Pacific Valve carries a few pieces of the Dodge line-up.
    nooshinjohn Posts: 26,086
    edited March 2012
    Don't forget the 1k shipping charge... I'd pass.
  • pyrocyborg
    pyrocyborg Posts: 524
    edited March 2012
    heiney9 wrote: »
    Speakers: Polk Audio LSiM 705, LSiM 703, LSiM 704c
    Receiver: Denon X3500H
    edited March 2012
    LOL
    Doge
    I think it's pronounced Doe Jay, since it's "high end".
  • pyrocyborg
    edited March 2012
    heiney9 wrote: »
    LOL
    Doge
    Or it could be Dog-gy
