Short single run or length of PNF Symphony Speaker Cable
Jer.War
Jer.War Posts: 180
edited March 2012 in Wanted (WTB) Classifieds
Interested in buying a single run or length of unterminated PNF speaker cable. I am hoping to make jumpers to compliment the PNF cables I have running to my mains. Getting anything from PNF now-a-days seems to be a fool's errand, so I think this is my only hope.
Thanks,
Jer.
[The Ever-Evolving System
LSI15's (PNF Symphony cabels, modded X-Over and subs), LSIC, LSI7's, Rega Apollo CDP (PNF ICON ICs, modified PS cct.), Yamaha RXV-1700 w/ ipod dock, B&K REF200.2 (fronts) Samsung BDP-1600, XBOX360, Patriot Box Office Media Player, 42" Samsung LCD.
Post edited by Jer.War on
  • headrott
    headrott Posts: 5,496
    edited March 2012
    Jer.War wrote: »
    Thanks,
    Jer.
    Let me think about it, but I am no long using my PNF cables terminated with a "blade" for my AI-1 Dreadnaught. You could simply cut the "blade" off and reterminate as you like. I may be willing to sell one to you, but would rather sell a pair as I don't know what I would do with the other. I am still trying to decide if I will use them again in the future though. I don't think I will, but want to think about it to make sure. Mine are the (at the time) new black with purple accents if that makes a difference. Also, they are not short runs by any means as they are about 9 feet.
    I know what you mean about trying to get anything from PNF Audio. A couple years ago when I got my cables, it took A LOT of pressuring to finally recieve them. Now, I'm sure it's worse.
    Greg
  • Jer.War
    Jer.War Posts: 180
    edited March 2012
    Sounds good let me know. I am definately interested.
  • headrott
    edited March 2012
    Would you consider buying the pair of cable lengths that have the blade(s) on one end? As I said, I don't want to sell just one and be stuck with the other. How were you planning on hooking the jumper cables up to your speakers? Bananas or Spades? I ask because the other non-blade end is terminated with Kimber PM-25 Postmaster spades. You put another one on the other ends of the jumpers and you would be set. Just let me know if this is OK.
    Greg
  • Jer.War
    Jer.War Posts: 180
    edited March 2012
    What would you want for the pair, though it may be outside what I wanted to spend one some jumpers....
  • headrott
    edited March 2012
    PM sent.
    Greg
