Short single run or length of PNF Symphony Speaker Cable
Jer.War
Interested in buying a single run or length of unterminated PNF speaker cable. I am hoping to make jumpers to compliment the PNF cables I have running to my mains. Getting anything from PNF now-a-days seems to be a fool's errand, so I think this is my only hope.
Thanks,
Jer.
Thanks,
Jer.
[The Ever-Evolving System
LSI15's (PNF Symphony cabels, modded X-Over and subs), LSIC, LSI7's, Rega Apollo CDP (PNF ICON ICs, modified PS cct.), Yamaha RXV-1700 w/ ipod dock, B&K REF200.2 (fronts) Samsung BDP-1600, XBOX360, Patriot Box Office Media Player, 42" Samsung LCD.
Post edited by Jer.War on
Thanks,
Jer.
Let me think about it, but I am no long using my PNF cables terminated with a "blade" for my AI-1 Dreadnaught. You could simply cut the "blade" off and reterminate as you like. I may be willing to sell one to you, but would rather sell a pair as I don't know what I would do with the other. I am still trying to decide if I will use them again in the future though. I don't think I will, but want to think about it to make sure. Mine are the (at the time) new black with purple accents if that makes a difference. Also, they are not short runs by any means as they are about 9 feet.
I know what you mean about trying to get anything from PNF Audio. A couple years ago when I got my cables, it took A LOT of pressuring to finally recieve them. Now, I'm sure it's worse.
Greg
"Have A Little Faith! And Everything You'll Face, Will Jump From Out Right On Into Place! Yeah! Take A Little Time! And Everything You'll Find, Will Move From Gloom Right On Into Shine!"- Arthur Lee -
Sounds good let me know. I am definately interested.
LSI15's (PNF Symphony cabels, modded X-Over and subs), LSIC, LSI7's, Rega Apollo CDP (PNF ICON ICs, modified PS cct.), Yamaha RXV-1700 w/ ipod dock, B&K REF200.2 (fronts) Samsung BDP-1600, XBOX360, Patriot Box Office Media Player, 42" Samsung LCD. -
Would you consider buying the pair of cable lengths that have the blade(s) on one end? As I said, I don't want to sell just one and be stuck with the other. How were you planning on hooking the jumper cables up to your speakers? Bananas or Spades? I ask because the other non-blade end is terminated with Kimber PM-25 Postmaster spades. You put another one on the other ends of the jumpers and you would be set. Just let me know if this is OK.
Greg
What would you want for the pair, though it may be outside what I wanted to spend one some jumpers....
PM sent.
Greg
