wire hittin the cone?????
Systems
Systems Posts: 14,872
edited April 2004 in Car Subwoofer Talk
me and my buddy was watchin the adire brahama video that showed a 10 inch poundin like crazy and we went out to my car poped the trunk and checked mine out and it was movin preatty far out for the small sorround and iv noticed when i turn it up it make a weird noise and my buddy said it sounded like my wire was hittin the cone???i had to send my other back to get a new one couse the wire from the cone goin to the terminal came off.if my wire it hittin the cone is there anyway to fix that?????couse i dont wanna have to get it fixed couse my warrenty is allmost up.
Testing
Testing
Testing
  • neomagus00
    neomagus00 Posts: 3,899
    edited April 2004
    this problem, known as tinsel slap, is generally resolved by not over-driving your sub. any strange noises - most especially if you have a brahma - coming from your sub tell you that you need to turn it down right away. many subs use tinsels woven into the spider as a resolution to this, so look in to subs that do that if it bothers you. but it shouldnt make abnormal noise in any case.
  • Systems
    edited April 2004
    you can only hear it if your trunk is open.inside the car you cant hear it.it sounds fine in the car its just when you open the trunk and play it it make the sound.its a polk audio gnx 104 10 inch in a sealed box
    Testing
    Testing
    Testing
  • neomagus00
    edited April 2004
    no, it's not a problem then. if you haven't broken your subs yet, you probably won't anytime soon :).
  • Systems
    edited April 2004
    ok cool thx man.i was hopin it wouldent screw the sub up
    Testing
    Testing
    Testing
  • neomagus00
    edited April 2004
    nah, it's probably been doing it since the beginning. or have you listened before and just noticed it - ie is it something that you know for sure is a new issue?
  • Systems
    edited April 2004
    no its done it for a while and i dident think anything of it but my buddy said ah sounds like your wire is hittin the cone.but i guess if it dident do anything yet it probably wont
    Testing
    Testing
    Testing
  • Systems
    edited April 2004
    i have 2 gnx104's, and ive noticed a slightly weird sound coming out of them also, but its only when the volume is really high, with the right frequency, so just turn it down a bit and its gone
    Testing
    Testing
    Testing
  • Systems
    edited April 2004
    im gettin a new amp that has more options and it should sound fine then.just cant wait to get 3 baby momos
    Testing
    Testing
    Testing
