Any Polkies run a camera repair shop?
gwh
Picked up a Nikon D40 at a garage sale that takes very very dark pictures and sometimes displays error messages when you try to take a picture. I dont have much in it and if I can get it fixed fairly cheap I'd keep it for a back up or whatever. Might have some gear to trade (nothing spectacullar) and or $.
Thanks,
G
Thanks,
G
HT:
Martin Logan Motion 40
Martin Logan Motion 50XT
Emotiva Airmotiv E2
SVS SB16 Ultra
Def Tech Reference Sub
Yamaha RX-A3070
Signal Cable speaker wires & interconnects.
Emotiva Airmotiv E2
SVS SB16 Ultra
Yamaha RX-A3070
Post edited by gwh on
Id give this a shot -
In your menu under Custom Setting Menu, choose Menu Reset- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Plenty of them out here in Japan if you wanted to ship it out for repairs.Shoot the jumper.....................BALLIN.............!!!!!
Thanks, I almost threw away a Lumix DMC-FZ7 because the optical zoom wouldn't work
I refuse to argue with idiots, because people can't tell the DIFFERENCE! -
Sounds like what happened to my son's D40 after many thousands of exposures. There's a well-known failure mode. He had Nikon fix it; the cost (out of warranty) was somewhat less than the street value of a used D40. He, kindly, passed the repaired camera on to his sister :-) and bought himself a new-to-him Nikon D200.
Here's the scoop.
http://icouldbeahero.blogspot.com/2011/11/6.html
