NAD 3080 Integrated w/ Right channel issues
rromeo923
rromeo923 Posts: 1,513
edited March 2012 in 2 Channel Audio
I bought this about a year ago but havent really used it much. I hooked up a turntable and it sounds great. Until the right channel started going out. Static sound and then no sound out of the right channel. Both front and rear speakers. This was out of phono 1. Hooked up to Phono 2 and everything ok. So ifigure something in the right channel Phono 1 connection.
Any ideas??
I got static in my head
Post edited by rromeo923 on
  • TNHNDYMAN
    TNHNDYMAN Posts: 2,145
    edited March 2012
    Pull the cover and check for a cold solder joint on the rca plugs for phono 1. If both phono 1 and 2 are the same, ie not set up seperately for MM or MC cartridges then just use other phono input. You could try using some deoxit on the bad jack. IF you can will the rca jack and get sound out of it, it sounds like a intermittent bad connection inside the unit.
  • sucks2beme
    sucks2beme Posts: 5,691
    edited March 2012
    spay the jack?
    Try spaying the front panel selector switch.
    That or a solder joint loom as the most likely problems.
  • thsmith
    thsmith Posts: 6,082
    edited March 2012
    Might also check the RCA center pin tension on the phone 1 input for right channel.
  • rromeo923
    edited March 2012
    Took cover off and deoxit on rca jacks, front panel selector, speaker connections etc. Fired it up and it is now working.
    Now lets see for how long.
    If deoxit was all it needed then I am givin props to deoxit!
  • TNHNDYMAN
    edited March 2012
    good to hear romeo, if it happens again I'd bet it's a solder joint- enjoy the music
  • rromeo923
    edited March 2012
    Now I am actually noticing a slight channel imbalance. The right channel is now stronger than left. Not a whole lot but definitely noticeable and viewable wth VU Meter.
    Changed cables etc, same prob phono and aux (cd).
    Any ideas what might cause and how to fix?
