Cleaning a record with wood glue
halo71
I am a vinyl noob, but I have never heard of this. And would not have thought it would work.
http://youtu.be/_gyvipBs6Vs
EDIT: Well, I can't embed a vid anymore here I guess....
--Gary--
Been posted here before.
I would not do that to my albums.
Check this out and if you decide to make your own solution I have lab grade surfactant
http://www.teresaudio.com/haven/cleaner/cleaner.htmlSpeakers: SDA-1C (most all the goodies)
Gary, you been licking tweeters again? There are other ways to clean a record also.>
>This message has been scanned by the NSA and found to be free of harmful intent.< -
lol. no Ken. Only EMIM's in my Infinity's! :cheesygrin:
I just found it interesting. Never seen that method before.--Gary--
I purchased one of those paint tools that gets you close to the trim which has a very soft nap. Any used album I buy gets washed with that, a very small amount of dawn detergent, and water at the kitchen sink. I then lay the vinyl between two paper tools and gently press but don't rub. Gets them really clean.SDA2BTL
Marantz CD5004
Adcom GFA-545
Bottlehead Quickie Tube Preamp -
I ran across a guy selling a Nikon D100 DSLR on CL for cheap. He was a pro and said the camera had only one problem. He tried to clean the sensor himself with what he described as an industry trade secret... Scotch tape. That is right, apply the sticky side to the sensor and pull. The problem was that some of the adhesive stuck to the sensor.
Just because it is an idea, doesn't mean it is good. :redface:
No, I didn't buy...Stan
Main 2ch:
HT:
Other stuff:
Polkersince85 wrote: »Gary, you been licking tweeters again?
What? You mean someone else besides me is doing it?Marantz AV10-Emotiva ERC3-Denafrips Venus-Panasonic UB9000-AudioQuest Power Quest 707-Emotiva DR3, DR2, XPA2, XPA6-Focal Kanta No2, Sopra Center-PolkAudio RTiA9, RTiA3, LSiM 702F/X-Epik Empire-11.2 -
Ive done this on some old albums to try it out and it worked quite well. They were stored in a damp basement and had who knows what on there surface. I took pretty much everything off of them.
I used the glue method with a couple of hard-to-find LP's that were really dirty and that my normal cleaning didn't seem to remove enough pops/ticks to get them to a reasonable level. It works. I did mix a little Dawn dish detergent in the glue to get it into the grooves better. I would only go to the effort/risk as a last resort, however it's not as goofy as it sounds.DKG999
