Confusing ground loop problem!
joeparaski
This seems strange to me. I am trying to trouble shoot a ground loop problem. The amp is plugged into the wall and there is a hum from the speaker.....ok. Then, I happened to plug an extension cord between the same amp and the wall....and the hum goes away! huh! WTH...hum without extension cord and no hum with extension cord....WHY???
Joe
Joe
Amplifiers: 1-SAE Mark IV, 4-SAE 2400, 1-SAE 2500, 2-SAE 2600, 1-Buttkicker BKA 1000N w/2-tactile transducers. Sources: Sony BDP CX7000es, Sony CX300/CX400/CX450/CX455, SAE 8000 tuner, Akai 4000D R2R, Technics 1100A TT, Epson 8500UB with Carada 100". Speakers:Polk SDA SRS, 3.1TL, FXi5, FXi3, 2-SVS 20-29, Yamaha, SVS center sub. Power:2-Monster HTS3500, Furman M-8D & RR16 Plus. 2-SAE 4000 X-overs, SAE 5000a noise reduction, MSB Link DAC III, MSB Powerbase, Behringer 2496, Monarchy DIP 24/96.
Post edited by joeparaski on
Does amp and EC have ground plug?
Maybe EC has flipped polarity ?Speakers: SDA-1C (most all the goodies)
The cheap "fix" for a ground loop is to use a grey 2-prong grounding adapter on the grounded cord of the guilty component. This takes the ground out of the equation. If you are somehow plugging a 3-prong cord into a 2-wire extension cord, that would do the trick.VTL ST50 w/mods / RCA6L6GC / TlfnknECC801S
Conrad Johnson PV-5 w/mods
MF x-DAC V8, HAInfo NG27
NAD SS rigs w/mods
GIK panels -
The amp has a 3 prong cord. Plugging it directly into the wall causes a hum in the speaker (the surrounds in this case). Plugging the amp into the wall but adding a 3-prong extension cord made the hum disappear....which is very strange.
JoeAmplifiers: 1-SAE Mark IV, 4-SAE 2400, 1-SAE 2500, 2-SAE 2600, 1-Buttkicker BKA 1000N w/2-tactile transducers. Sources: Sony BDP CX7000es, Sony CX300/CX400/CX450/CX455, SAE 8000 tuner, Akai 4000D R2R, Technics 1100A TT, Epson 8500UB with Carada 100". Speakers:Polk SDA SRS, 3.1TL, FXi5, FXi3, 2-SVS 20-29, Yamaha, SVS center sub. Power:2-Monster HTS3500, Furman M-8D & RR16 Plus. 2-SAE 4000 X-overs, SAE 5000a noise reduction, MSB Link DAC III, MSB Powerbase, Behringer 2496, Monarchy DIP 24/96. -
I am guessing that the 3 prong extension cord isn't grounded properly or has a break in the ground wire.polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
That's not it either. I tried a second 3-prong extension cord, same result, the hum diminished greatly. I think it may have something to do with the "winding" of the cord. It's a 25' cord that is rolled up.
Could be a host of reasons, from the outlet itself to the cords ability to shield out interference, quality of the cord, etc. Either way, maybe try a different power cord on the amp or pick up a 2 buck cheater plug and see if that works.
Chasing down ground loops can be a pain, sometimes you think it's one piece of gear and it could be another thats connected to it. A bad interconnect, cable tv box, or the wall outlet itself. Obviously the hum wasn't always there so try and think of anything you may have changed around.HT SYSTEM-
lsi 9's -
Maybe the twist in the cord is resulting in less interference and you are not actually hearing a ground loop hum? Either way, these problems can sometimes be difficult (or easy) to chase down from my experience.polkaudio RT35 Bookshelves
