Would like some advice on how to set up my surround speakers
soccerfreak6789
soccerfreak6789 Posts: 4
edited March 2012 in Speakers
Hi everyone, I have a quick question about which I would like some advice. I have polk monitor 40's as surround speakers but I'm not sure how I should set them up. I am thinking of wall mounting with the pinpoint AM40 mounts:
http://www.amazon.com/Pinpoint-AM-40B-Clamping-Bookshelf-Speaker/dp/B002UV03MW
However, I'm not sure if wall mounting is the best solution for my set up. I attached a few pictures of my living room below. It seems to me that the left side of the couch would be fine but I don't know about the right side with the doorway right there. Would it be alright to wall mount it basically in the same position it is now on the end table except higher up? I feel like it would be better if it were a little further away but I guess there aren't too many other options. Any advice would be greatly appreciated! Thanks so much.
Post edited by soccerfreak6789 on
  • Geoff4rfc
    Geoff4rfc Posts: 2,838
    edited March 2012
    I had my M40's mounted up high and wide over the listening area similar to yours. Spreading them out one to the corner and other just inside the door jam sounds like a good idea. Angled down is recommended.
    Set up:
    Marantz AV8802A - Sources: BRP Panasonic 9000/CDP Emotiva ERC 3 - Display: LG OLED EVO 83 C3 - Amplification: Emotiva XPA-DR3, XPA-6, XPA-2 x 2 - Speakers: Focal/PolkAudio, Mains/2ch - Kanta No2, C - LSiM706, SS - LSiM702, WS - RTiA9, RS - RTiA9, FH - RTiA3 - Subs: Epik Empires x 2
    Cables: AQ McKenzie XLR's from CDP to AVP to amp for 2ch, Emotiva XLR's for the rest - Douglasconnection: Furutech Alpha 36 12g speaker wire for 2ch, Furez 10g speaker wire for the rest - AQ Forest48 HDMI for the display, AQ Carbon48 HDMI from BRP to AVP - VR3 filtered power cables for CDP, BRP and AVP, Emotiva power cables for the amps - AudioQuest 505 power conditioner.
  • soccerfreak6789
    edited March 2012
    should they be kept at a similar distance from the seating though? Or does it not matter much for the surrounds? The corner on the one side is quite a bit further away from the door on the other. Also, I'll have to check to see where studs are located but I'm not sure if I'll be able to put it all the way over to where the door is
  • Geoff4rfc
    edited March 2012
    The distance you have now at the sides of the couch are good, if you wanted, you could widen them out a tad bit. Sure, I'd check to see where your studs are and then go from there. Ten to twelve inches out from the edge or the couch is cool, raise them as high as you like. Most likely a couple of feet or so.
    Set up:
  • hochpt21
    hochpt21 Posts: 5,423
    edited March 2012
    Your surrounds don't necessarily need to be equal distance to the listening area. Sure, it would be ideal, but most AVRs have distance settings that you can manually set or the auto-calibration will set it for you.
  • soccerfreak6789
    edited March 2012
    ok thanks for the help guys! I've heard a couple of different opinions on height for surrounds as well as angling them down vs keeping them straight. If I raise them up just a couple feet to be above the listening level but not all the way up, would I still want to angle them, or is that just if I were to raise them up higher?
  • pearsall001
    pearsall001 Posts: 5,291
    edited March 2012
    2-3' or approx. 6' above your seating ear height is the recommended height positioning. As far as mounting goes, I would suggest trying them in both positions...angled & straight & go with what sounds best to you in your room.
  • Geoff4rfc
    edited March 2012
    I've always preferred to have mine angled down regardless of distance.
    Set up:
  • soccerfreak6789
    edited March 2012
    Thanks a lot guys! I'll do that. I really appreciate the help
  • specd_out
    specd_out Posts: 505
    edited March 2012
    I have a very similar setup up in my living room. My speakers are mounted on the wall angled down and toed in. I will post a photo when I get home tonight
    HT Rig Samsung 64F8500 |Pioneer Elite BDP-52FD|Pioneer Elite VSX-32| Two Carver TFM-15cb Bridged for mains|Polk Audio RTiA5 Cherry|Polk Audio CsiA6 Cherry|Polk Audio T-15 Heights|Polk Audio FXia6 Surround|DIY 8cuft Dayton Ultimax 15" powered with a Crown XLS1000
    2Channel Rig Polk Audio LSi9 Cherry| Carver C-1BillD Mod|Carver M1.0t MkII Opt2|Pro-ject RM 1.3|SpeedBox S|AQ King Cobras|AQ Rocket88|
    ISF Level 2 Certified Calibrator
