MM1040 Subwoofers
Toolfan66
Toolfan66 Posts: 18,067
edited March 2012 in Car Audio & Electronics
Any one using these? I am thinking of putting dual 10's in my Camaro, Not that I need dual's but I like the subwoofer box configuration better in the trunk. I'm not trying to rattle my car apart as I drive down the road either, I just want some better bass coming from my car..
I should note I am not a guru at car stereos, so any help would be awesome..
Thanks!!
Post edited by Toolfan66 on
  • arun1963
    arun1963 Posts: 1,797
    edited March 2012
    Two tens would be fine. Not sure how noisy or quiet the Camaro is, but I have a feeling the two 10's would be ideal. To get a sub sounding the way it should you need to take care of three things. Keeps the gains on the amp low, cut the sub~40-60hz on a steep slope and get the right size sealed box. That will give you a nice tight fill in for the lower end.
  • pentoncm
    pentoncm Posts: 379
    edited March 2012
    Why not two 12's ?:twisted:
    I hope you have some nice mids in the front.
    Audison Bit Ten
    Kenwood X595
    Polk MM6501
    Polk MM1240
    Mtx 704x
    Alpine MRX50
  • pentoncm
    pentoncm Posts: 379
    edited March 2012
    They are cheap at onlinecarstereo.com.
    Audison Bit Ten
    Kenwood X595
    Polk MM6501
    Polk MM1240
    Mtx 704x
    Alpine MRX50
  • kawizx9r
    kawizx9r Posts: 5,150
    edited March 2012
    Had a single MM1040 hooked up to a JL Slash 500/1, loved every minute of it.
    The MM's sound amazingly clean in a sealed enclosure and sized to spec. I'm contemplating getting 2 ten's for my truck; right now I have 2 10" Rockford Fosgate P1's that sound nothing like the Polk's did granted they are entry-level from RF.
    Truck setup
    Alpine 9856
    Phoenix Gold RSD65CS
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Any clue how to use the internet? Found it in about 10 sec.
  • MacLeod
    MacLeod Posts: 14,358
    edited March 2012
    I can vouch for them. Ran a pair of 10's for 2 years in MECA. In hind sight, I'd rather have the 12's. 12's are just the best size of sub for music IMO. But a pair of MM10's will certainly get the job done.
    edited March 2012
    Thanks guys, I figured two 10's would do the job, I have 8 sheets of Dynamat on the way, I'm looking forward to starting this project so I will have more questions as I move along.
  • kawizx9r
    edited March 2012
    Toolfan66 wrote: »
    8 might over do it, so you should just send a couple sheets my way :mrgreen:
    What do you plan on powering the MM's with? Going with two SVC or DC subs?
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
  • MacLeod
    edited March 2012
    Im of the belief that you can never have too much Dynamat.
  • kawizx9r
    edited March 2012
    MacLeod wrote: »
    Shhhh! :wink:
    Btw, post some pics Larry when you get things rolling!
    Truck setup
    Alpine 9856
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
  • MacLeod
    edited March 2012
    I just bought a couple Dynamat door kits. One for each door with some left over to get other panels around the dash and such. Having everything good and dampened really helps a lot in isolating the music from the rest of the car. You can really tell the difference in cars that have yanked out the interior and Dynamated everything. That costs am arm and a leg tho and more work than I'm willing to put into it tho. LOL.
  • arun1963
    edited March 2012
    When I get a new car I'm going to spend on dynamat to cover the floor, foot wells, firewalls and the boot. It costs about 50 bucks to do a door, I think the entire car will cost a bit. Of course I would increase the vehicle weight and hence raise the gas bills. Since I'm not going to spend on new equipment, I think I'll spend a bit here. It should help in maintaining sound quality while on the move.:smile:
  • MacLeod
    edited March 2012
    It definitely makes a big difference. You can almost instantly tell the cars that have deadened the entire interior. You dont feel anything resonating or vibrating and the music seems "separated" from the car and not part of it like it does without the deadening. If I had tons of cash, Id drop mine off at a shop and let them yank everything out but there is no way Im gonna go thru all that headache and time!
