Just when I thought the compulsion to upgrade was under control . . .
Mike,
Do you think these are official releases? The package looks great and I might have to pick that up too..
And yes you should open it!!:razz: -
By now we all know you have opened it
"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
Everything I've purchased from Soundstage Direct has been an official release, so I don't see why not.
The only reason I may not open it is that the CD/DVD set is a collectable: http://www.amazon.com/Salival-Tool/dp/B0000541I5"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
If I told you I picked up the CD/DVD set off eBay for $40 would you believe me? I knew if I didn't hit that buy it now button I would kick my **** for days..
I will have a hard time opening the Aenima LP when it comes but I know I will, you only live once so should you preserve it for someone else?:eek: -
I only spent a little more on the cd/dvd box IIRC.If I told you I picked up the CD/DVD set off eBay for $40 would you believe me? I knew if I didn't hit that buy it now button I would kick my **** for days..
I will have a hard time opening the Aenima LP when it comes :cool:but I know I will, you only live once so should you preserve it for someone else?:eek:
I'll open it next time I break out the lp cleaner.:cool:"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
You better! What good is vinyl if it isn't spun?I only spent a little more on the cd/dvd box IIRC.
I'll open it next time I break out the lp cleaner.:cool:polkaudio Monitor 5 Series II
polkaudio SDA-1 (with the SL1000)
TEAC AG-H300 MK III stereo receiver
beyerdynamic DT-880 Premium (600 Ω) headphones
SENNHEISER HD-555 headphones
Little Dot MK IV tube headphone amp
Little Dot DAC_I balanced D/A converter -
Hey Face,
I opened mine last night and slapped it down on the platter. It's awesome, but I think it's a bootleg nonetheless. Still a fun token if you are a collector of all things Tool.
