Just when I thought the compulsion to upgrade was under control . . .
    Toolfan66 Posts: 18,068
    edited February 2012
    Face wrote: »
    Should I open it or no? :evil:
    Attachment not found.
    Mike,
    Do you think these are official releases? The package looks great and I might have to pick that up too..
    And yes you should open it!!:razz:
    EndersShadow Posts: 17,705
    By now we all know you have opened it :smile:
  • Face
    Face Posts: 14,340
    Everything I've purchased from Soundstage Direct has been an official release, so I don't see why not.
    The only reason I may not open it is that the CD/DVD set is a collectable: http://www.amazon.com/Salival-Tool/dp/B0000541I5
    If I told you I picked up the CD/DVD set off eBay for $40 would you believe me? I knew if I didn't hit that buy it now button I would kick my **** for days..
    I will have a hard time opening the Aenima LP when it comes but I know I will, you only live once so should you preserve it for someone else?:eek:
  • Face
    Face Posts: 14,340
    Toolfan66 wrote: »
    I will have a hard time opening the Aenima LP when it comes :cool:but I know I will, you only live once so should you preserve it for someone else?:eek:
    I only spent a little more on the cd/dvd box IIRC.
    I'll open it next time I break out the lp cleaner.:cool:
  • Bobsama
    Bobsama Posts: 526
    Face wrote: »
    You better! What good is vinyl if it isn't spun?
    polkaudio Monitor 5 Series II
    polkaudio SDA-1 (with the SL1000)
    TEAC AG-H300 MK III stereo receiver
    beyerdynamic DT-880 Premium (600 Ω) headphones
    SENNHEISER HD-555 headphones
    Little Dot MK IV tube headphone amp
    Little Dot DAC_I balanced D/A converter
  • SolidSqual
    SolidSqual Posts: 5,218
    Hey Face,
    I opened mine last night and slapped it down on the platter. It's awesome, but I think it's a bootleg nonetheless. Still a fun token if you are a collector of all things Tool.
