Yaqin AMPS
kermit_xc
kermit_xc Posts: 10
edited February 2012 in Electronics
anybody here has any experience with the Chinese tube amps?
Post edited by kermit_xc on
  • polkfarmboy
    polkfarmboy Posts: 5,703
    I myself for one and michaelj ... both of us are fond of yaqin integrated tube amps
    You get a really great sound for the money and the build quality is pretty good as I dont really ever hear of defects from bad manufacturing
  • michaeljhsda2
    michaeljhsda2 Posts: 2,205
    +1. Yaqin also makes a pretty respectable tube buffer as well as other offerings. Buy with confidence from the Ebay seller Tabnaac from Canada (no affiliation) who does a QC on every piece of gear before it's shipped out. Great bang for the buck and quality gear. I highly recommend the MS-20L integrated. There's an extensive thread at Audiokarma about the MS-20L.
    SDA SRS 2.3TL's
    SDA 2B TL's
  • pietro944
    pietro944 Posts: 720
    My Yaqin Cd3 tube buffer with Jan-Phillips 6922's is way better than just respectable....truly revealing with impressive build quality.
  • marvda1
    marvda1 Posts: 4,963
    kermit, i have the yaqin ms 20l, you can kill two birds with one stone and listem to the onix reference one driven by the yaqin.
    got my ms 20l for $485 shipped, it was 3 months old. they don't last long on audiogon when they come up. i have yet to run across any negative comments in a long while.
    Puritan PSM156
