Car help/suggestions
ratster
Getting my disabled father in and out of my pick-up is getting difficult,so I'm thinking about a new to me car.I have pretty much narrowed it down to 3
choices.
1.Subaru Outback
2.Honda CR-V
3.Honda Element
They are all lower than my pick up and have room for a wheel chair and a dog,but I don't know a thing about any of them.Suggestions,tips,anything to look for on these models?
Thanks,
Rhett
choices.
1.Subaru Outback
2.Honda CR-V
3.Honda Element
Thanks,
Rhett
Main
Parasound P5
Parasound A21
CA music streamer
marantz 6005
Clear Day dbl.shotgun
Morrow Xlr
1.7 Maggies
Bedroom
adcom Gfp750
Adcom 555
Rotel 1072
CA tuner
LsiM703
Clear day dbl shotgun
Parasound P5
Parasound A21
CA music streamer
marantz 6005
Morrow Xlr
1.7 Maggies
Bedroom
adcom Gfp750
Adcom 555
Rotel 1072
CA tuner
LsiM703
I'll say this: I like my 08 CR-V. I actually find it to be just the right height for me (~5'9"). I don't really have to go up or down to get in, I just kind of slide in. That means, I can also just slide out and not have to go up or down then either.Getting my disabled father in and out of my pick-up is getting difficult,so I'm thinking about a new to me car.I have pretty much narrowed it down to 3
choices.
1.Subaru Outback
2.Honda CR-V
3.Honda Element
Thanks,
Rhett -
I don't think you could go wrong with any of those choices. All very reliable, well-built vehicles. The CR-V might still be a little too tall, depending on how disabled your father is. There's two CR-Vs in my family, and while they aren't pick-up truck tall, it's still a bit of a step up. Wouldn't ask my 5'2" grandma with osteoporosis to try to get into one. With her in mind I'd pick the Outback, which is the most car-like of the bunch. But she is an extreme case.
Monster AVL-300, HTS-2500 MKII -
Similar situation with my mother in law and her hip replacement. We ended up with a Pontiac Vibe which turned out to be a nice level. Higher than my normal sedan, but not up at the level of my wife's Murano. I believe the Vibe is actually a relabeled Toyota Matrix.integrated w/DAC module Gryphon Diablo 300
server Wolf Alpha 3SX
phono pre Dynamic Sounds Associates Phono II
turntable/tonearms Origin Live Sovereign Mk3 dual arm, Origin Live Enterprise Mk4, Origin Live Illustrious Mk3c
cartridges Miyajima Madake, Ortofon Windfeld Ti, Ortofon
speakers Rockport Mira II
cables Synergistic Research Cables, Gryphon VPI XLR, Sablon 2020 USB
rack Adona Eris 6dw
ultrasonic cleaner Degritter -
Yes it is. Joint venture between GM and Toyota if I understand correctly...polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
Which year CR-V? I ask because the 2007+ model years are lower to the ground than prior years.I don't think you could go wrong with any of those choices. All very reliable, well-built vehicles. The CR-V might still be a little too tall, depending on how disabled your father is. There's two CR-Vs in my family, and while they aren't pick-up truck tall, it's still a bit of a step up. Wouldn't ask my 5'2" grandma with osteoporosis to try to get into one. With her in mind I'd pick the Outback, which is the most car-like of the bunch. But she is an extreme case. -
My aunt has one of the older, boxier ones, probably around a 2000 or so, and one of my in-laws has a 2008. The '08 is probably a bit lower than the '00, but still not as low as a car. My grandma is 5'2" and shrinking because of osteo, and any sort of a step up would be near impossible for her. She couldn't get into either. In fact I'm not even sure she could make it into the Outback, but like I said she is an extreme case. Right now she rides around in a Cadillac SLS, which she can just sit down in.
My sister has a CV-4 and is looking to get something else as it is getting too hard for her to get in and out of it (she's had 2 knee replacements and a hip replacement), as well as my Mom who is 88 and has problems with her legs. So it may not be the best choice for someone who is disabled. They are both on the short side though so it may be different for men. It is one of the higher ranked used vehicles though. I think hers is an '05. (just 39,000 miles and near immaculate if anyone is interested
) 2 channel - Willsenton R8 tube integrated, Holo Audio Spring 3 KTE DAC, audio optimized NUC7i5, Windows 10 Pro/JRiver MC29/Fidelizer Plus 8.7 w/LPS and external SSD drive, PS Audio PerfectWave P3 regenerator, KEF R3 speakers, Rythmik F12SE subwoofer, Audioquest Diamond USB cable, Gabriel Gold IC's, Morrow Audio SP5 speaker cables. Computer - Windows 10/JRiver, Schiit Magni 3+/Modi 3+, Fostex PMO.4n monitors, Sennheiser HD600 headphones -
Yeah, that does sound like an extreme case. My grandmother is 87, and around 5'4", but very, very weak due to spinal cord compression. At any rate, it is near impossible to get her into my mother's Toyota 4Runner. So, if we all go out, we take her in my CR-V, as it is much easier for her to get in and out of it. The thing is, lower cars aren't really better in this case. It's easier getting her in, but more difficult to get her out since we have to help her up rather than just sliding her out.My aunt has one of the older, boxier ones, probably around a 2000 or so, and one of my in-laws has a 2008. The '08 is probably a bit lower than the '00, but still not as low as a car. My grandma is 5'2" and shrinking because of osteo, and any sort of a step up would be near impossible for her. She couldn't get into either. In fact I'm not even sure she could make it into the Outback, but like I said she is an extreme case. Right now she rides around in a Cadillac SLS, which she can just sit down in.
Keep in mind that a lower car will be easier to get into, but may be more difficult to get out of. So, there may not necessarily be a better solution. And, in this case, even a newer model CR-V may be a better option. Just something to think about. :cheesygrin:dragon1952 wrote: »My sister has a CV-4 and is looking to get something else as it is getting too hard for her to get in and out of it (she's had 2 knee replacements and a hip replacement), as well as my Mom who is 88 and has problems with her legs. So it may not be the best choice for someone who is disabled. They are both on the short side though so it may be different for men. It is one of the higher ranked used vehicles though. I think hers is an '05. (just 39,000 miles and near immaculate if anyone is interested
