Hey
Systems
Systems Posts: 14,872
edited April 2004 in Car Audio & Electronics
I drive a 94' Honda Accord Sedan and plan on replacing all 4 of my speakers with new Polk Audio speakers. Anyone have any suggestions on which front/rear speakers I could get. The diameter according to the fit guide for my speaker is 6-1/2'' and I have an Alpine stereo unit. Thanks all greatly appreciate it.
Testing
Testing
Testing
  • Systems
    edited April 2004
    Money is not a problem here, I just want the best quality, and sounding stuff thanks all.
    Testing
    Testing
    Testing
  • exalted512
    exalted512 Posts: 10,734
    edited April 2004
    im guessing you have 6.5s in front and 6x9s in the back?
    just get the mm6s along with the c300.2 amp to power them and run the 6x9s off the deck
    -Cody
  • Systems
    edited April 2004
    damn would it run fine with jus the speakers or do i gotta throw out some cash for the amp too...
    Testing
    Testing
    Testing
  • Systems
    edited April 2004
    I need an amplifier to power the new speakers im getting? I'm really ignorant about these stuff but I thought you only need an amp when you got some subs. All I want as of right now is new speakers and that's it, Will it still work fine and have it's top performance with nothing?
    Testing
    Testing
    Testing
  • exalted512
    edited April 2004
    if you dont want to add an amp, dont get the mm6 components
    go with the momo 6.5" coaxials
    those will run great off the deck, component speakers dont do so hot off of a deck, especially the power hungry momos
    -Cody
  • GetB1azed
    GetB1azed Posts: 14
    edited April 2004
    After looking into the amp/subwoofers lol I kinda want them now lol... I think im going to get new speakers front/rear a good amp that can run with it and a subwoofer too. I don't know how I'll be able to pick which one goes with which... like which one is compatible with the other. And also for the Fit Guide thing I put in my car model and it says 6-1/2'' front and rear.. but my brother and you told me the back is 6by9 its weird.. Well tell me what you think would be nice subs/amp/speakers that will put out some great sound thanks
    -John
  • exalted512
    edited April 2004
    from sounddomain.com you can pick up a mm12 in box for $180
    that is a TERRIFIC price
    get the c300.2 to power it
    if you want the best sound quality that polk offers, get the mm6s and the c300.2 to power them
    there are some cheaper alternatives on amps but not by polk
    ill post up some links if you want
    so in all:
    2 c300.2 amps
    1 pair of mm6 components
    1 mm12 sub with enclosure
    its probably very easy for you to check
    if you have grilles on your rear deck, are they a circle or an oval?
    oval=6x9s
    round=6.5s
    if you dont have grilles, then pop your trunk and look at where your rear deck would be
    do the speakers look oval about 6" across by 9" long?
    or do they look round?
    now this isnt an exact science, there ARE other sizes that they could be, but in reality, theyre probably 6x9s
    -Cody
  • GetB1azed
    GetB1azed Posts: 14
    edited April 2004
    thanks man im thinking either infinity or polk not sure yet tho lol
  • GetB1azed
    GetB1azed Posts: 14
    edited April 2004
    my bro works at this place and they get accomodations with Infinity and Polk and he gets 65% off of original price so these set systems will probably be under 350$$ for me hopefully hehe...
  • GetB1azed
    GetB1azed Posts: 14
    edited April 2004
    Hey why do i need 2 amps thought i only needed 1... and also
    what is the mm6 i know the mm12 with enclosure is the sub unless the mm6 is also the pair of subs going into the enclosure too
  • exalted512
    edited April 2004
    the mm6 components are the 6.5" speakers
    they come with a separate tweeter
    they will give you the best sound
    the other option is the momo coaxial series
    the tweeter is part of the speaker
    they dont have the powerhandling the mm6 does
    if you dont want to have to get 2 amps, then get the coaxials
    if you want better sound quality that will get louder, get the mm6's with an amp
    -Cody
  • GetB1azed
    GetB1azed Posts: 14
    edited April 2004
    oh i see you got AOL or MSN lol
  • GetB1azed
    GetB1azed Posts: 14
    edited April 2004
    yo cody u got AIM or MSN
  • exalted512
    edited April 2004
    AIM
    s/n=exalted512
    -Cody
  • GetB1azed
    GetB1azed Posts: 14
    edited April 2004
