PB2-ISD Calibration
  • monkeyphant
    monkeyphant Posts: 79
    edited April 2004
    Here is the graph:
  • Dr. Spec
    Dr. Spec Posts: 3,780
    edited April 2004
    That is a very decent looking start to a house curve. Messing around with your phase control in 10 degree increments and running a sweep each time will more than likely identify a setting which significantly reduces the severity of that null at 80 Hz.
    In fact try 180 to start, and then try 110 (works well in my room - a shot in the dark, really).
    Regardless, you should have NO shortage of power and impact in the 20-60 Hz region - there are no ugly nulls in that bandwidth at all and you have really strong room gain. I say all you need to do for more power/impact is wick up the gain setting. That's the really good news in all of this.
    Also, how does your master volume affect the speakers and the sub - I noted you could alter the gain independently for the speakers. Are you sure you are providing an equal amount of gain to both the speakers and the sub as you increase your Master Volume setting?
    Doc
    SVS
  • monkeyphant
    edited April 2004
    Thanks, Doc. Adjusting the phase control and doing additional FR
    sweeps is my next step...
    I'm pretty sure I'm providing an equal amount of gain to both. I use my AVR as a preamp processor. The AVR preamp outputs are connected to my power amplifiers. The only time I alter the gain (turn them down completely) is when I take sub measurements, other then that they are at full volume (I think, but I'll make sure when I get home tonight).
    MP
  • monkeyphant
    edited April 2004
    Doc:
    I checked and I am providing an equal amount of gain to both the speakers and the sub as I increase my Master Volume setting. I used my new AVIA Calibration Disc for the first time last night. Strange thing...using the old VE at 75 db gave me insufficient PB2-ISD power even wicking up the sub plate gain to 78db; BUT with the AVIA, all surrounds at 85db and the sub at 89db, was more than enough power. I still want to do some FR sweep measurements, but the PB2 is not suffering from a lack of power/ volume/pressure anymore.
    MP
  • Dr. Spec
    edited April 2004
    MP
    Case closed; VE was the culprit. I swear by Avia for basic video and audio calibration. I even run Avia cool for the sub 85/83 and it's still strong. But I used to run 88-89 when I first had my PB2+, so I can appreciate your current taste in bass. As long as the PB2-ISD is living up to its billing and you are happy, that's all that matters.
    SVS
  • monkeyphant
    edited April 2004
    Thanks to DOC, pjdami, tryrrthg, PolkWannabie ....and a special thanks to VE for raising my blood pressure and keeping me awake at night...:p
    MP
  • pjdami
    pjdami Posts: 1,894
    edited April 2004
    MP,
    Congratulations on resolving the problem to your liking and you are welcome.
    Please do post a FR of the "post Avia" calibration FR because I am curious as to what the difference is between the new graph and the old one. So you didn't change any settings on the AVR or DVD player eh? How much more gain (relative to notches) did you have to add to the plate amp?
    Just curious. You actually looked pretty strong in bass response before based on the curve. I just wanted to see what the differences are.
    I have successfully used the Sound and Vision and Avia DVDs before; they are both made by Ovation. The S & V just seems to be the stripped down version and it's only 20 bucks.
  • monkeyphant
    edited April 2004
    PJ
    That's a good question. Since I'm not at home, I can only guess. I would say from about 1/4 to about a notch or two before 1/2, but that's with the PB2 running too hot at 89db. I'll work on a new FR sweep this weekend.
    MP
  • pjdami
    pjdami Posts: 1,894
    edited April 2004
    MP,
    So that means that you are close to the 12 o'clock position when looking at the sub amp plate dial? That's about where I am too.
    You should be well into the 100's with SPL between 20 - 30 hz with an increase in the sub amp plate there. Looks like you are going to be a little hot between 30 - 40 hz as well. That is fine if it is to you liking but there are some things you can do as if you find this setting a little too bass heavy for music. Really depends on you though and how it sounds to you.
    When you get a chance this weekend I would also like to see what kind of SPLs you are getting from the movie tracks you origianlly posted. Before and after.
    Happy Easter!
  • monkeyphant
    edited April 2004
    PJ
    I did my OVE FR sweep at -20RL. I'm thinking to do the AVIA FR sweep at about -30RL or so, since I don't know what to expect with the new AVIA calibration. It shouldn't make a difference since we are comparing frequency response.
    I'll reduce the plate amp gain to RL (83db) and record the movie SPLs again from the primary sitting position at -10RL.
    You have a nice holiday!
    MP
  • monkeyphant
    edited April 2004
    PJ
    MP
  • monkeyphant
    edited April 2004
    LOTR: The Ring Drop
    Iron Giant: Iron Giant fires on Battle Cruiser
    U571: German Sub under depth charge attack after destroying
    merchant vessel (highest SPL)
    The OVE measurements were taken at -10db below RL with the AVR at -6 and the PB2 calibrated at 75db.
    The AVIA measurements were also taken at -10db below RL with the AVR at -6 and the PB2 calibrated at 83 db.
    ..........OVE.......................AVIA
    ..........Calibration..............Calibration
    LOTR...94db.....................104db
    IG.......96db.....................106db
    U571...95db.....................107db
    Avg.....95db.....................105.6db
  • monkeyphant
    edited April 2004
    PJ
    Here is the FR sweep showing the AVIA calibration with the Phase at 0 and 90 degrees at -20 RL.:
  • monkeyphant
    edited April 2004
    ...and the OVE and Post AVIA calibration at -20RL at 0 Phase:
  • Dr. Spec
    edited April 2004
    Great work, MP. The right calibration disc makes ALL the difference, doesn't it? I bet you can FEEL that extra 10+ dB can't you? :cool:
    Nice to see the phase control making a difference. Keep tweaking it; 110 degrees works well in my room.
    Also try enabling the low pass at the highest setting and see what happens to that 90 Hz null. I know, it sounds counterintuitive, but just try it. Also, enabling the low pass is not for rookies - you need FR sweep capability to evaluate its effect and otherwise I recommend leaving it disabled.
    SVS
  • monkeyphant
    edited April 2004
    Thanks DOC...coming from you that's a real compliment! That extra 10+ db had me laughing like a mad scientist, especially the Iron Giant scene which I played about three or four times in a row. Man the house shook....
    My daughter told me that when I was doing the SPL movie calibration , Mrs. Monkey said: "I hate when your father does that. He's going to lose his hearing if he keeps that up :mad: !"
    Mrs. MP can't take a joke...
  • Dr. Spec
    edited April 2004
    And everyone should note that MP is running his sub FLAT at 83 dB with Avia.
    A truly powerful sub does not need to be run hot in order to impress. I run my PB2-Ultra the same way for HT, and even cooler for music (81 dB).
    The asking price is almost ridiculously low when you consider what that sub is capable of.
    Believe me, you've got some gas left in that tank; your PB2 isn't even breaking a sweat at 105-107 dB peaks at the seat. No need to push it louder, but it's nice to know you've got headroom galore to keep dynamics sharp and distortion low.
    SVS
  • monkeyphant
    edited April 2004
    Doc:
    Here's the latest FR sweep results using my Stryke Calibration disc at -20RL all speakers plus the PB2. I've gone from 90 degrees to 45 degrees. Also, I used my AVIA Disc to check the sub level which was at about 85db after running the FR sweeps. I am going to wick the plate gain back to 83 db. As you said, there's no reason to run the PB2 hot.
  • Dr. Spec
    edited April 2004
    Wow! Fabulous looking curve. Relatively flat from 100-40 Hz for accuracy on music, and then look out - free room gain for the super deep HT stuff! The best of both worlds.
    A first hand demonstration of the power of a CV phase control - a very good tool in the right hands. As you now know, it affects far more than the response at just the xo frequency. Really great work. I bet the sub sounds just awesome on both music and HT.
    Now that you have the sub dialed in, I would plug a port, drop the tune switch, and measure the increase in deep output. At the volumes you are hitting, you can afford to plug a port. You'll notice a difference on a handful of DVDs with true 15-20 Hz content. Something like U-571 dts, Revolutions, or the Daredevil dts bar fight scene are good examples.
    I'm betting you'll get good in-room extension to 16-17 Hz with a port plugged. Try it and see how you like it.
    After you calibrate to 83 dB with all ports open, up the sub level 1.5 clicks at the AVR when you plug a port. This will mostly compensate for the volume lost above the tune point and the curve in the 100-30 Hz region should look almost the same. You will get a slightly flatter looking curve in the 30-20 Hz region, and reap another 5 Hz extension at the very bottom. It should troll deeper than sin with a port plugged.
    Doc
    SVS
  • faster100
    faster100 Posts: 6,124
    edited April 2004
    I gotta get off my **** and do some FR sweeps and tune this isd i have.. run the dve disk... and hopefully i get that s&V disk soon in the mail... alotta good data here guys
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    LSIfx surround backs
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Rotel 1080 stereo amp
    Polk sda 2B
    kenwood grunt Tuner
    realistic lab 450 TT
    Signal cable IC
  • pjdami
    pjdami Posts: 1,894
    edited April 2004
    Looking really good monkeyphant. Hard work and patience has rewarded you. As Doc has suggested, (and I found this to be the case as well) porting a plug will help flatten that hump and give you deeper extension. Man, looks like you have some good acoustics for bass in that room.
    Faster.. Do it! You will learn a lot about your subwoofer and optimal room placement that way. This is one way to squeeze every little bit of optimal performance out of the hard earned money you spent on a sub.
  • Dr. Spec
    edited April 2004
    Disgusting, isn't it? Some guys have all the luck. My room is the same way. You've really struggled with your room acoustics, Paul.
    SVS
  • faster100
    edited April 2004
    Hey, Doc... what program are they useing to make that graph.. I just ran the test tones... and need something to make a graph with to see the ups and downs...
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
  • Dr. Spec
    edited April 2004
    Just a simple Excel spreadsheet. I developed one about two years ago and it spread all over the internet. Lots of other variations floating around too.
    SVS
  • faster100
    edited April 2004
    I have your spread sheet, But what did monkey use to make that graph picture?? above
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
  • faster100
    edited April 2004
    wow either i did something wrong or this graph is crazy
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
  • pjdami
    pjdami Posts: 1,894
    edited April 2004
    yeah faster. Something isn't right. Can you post the sheet with the data? Let's see what is going on.
    P.
  • HBombToo
    HBombToo Posts: 5,256
    edited April 2004
    Yikes!
    ***WAREMTAE***
  • faster100
    edited April 2004
    how do i post the excel sheet
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
  • pjdami
    pjdami Posts: 1,894
    edited April 2004
    should be able to post it just like you did the graph above. Just a different sheet in the workbook. Same principle.
    Or you can copy your desktop image and paste it in a .jpg / .gif file
    Just curious. Is your raw uncorrected data that low in dbs (56)from 40 hz to 85 hz?
