Building a HTPC....
On a sidenote, something I discovered:
Multichannel out over digital interfaces usually requires Dolby Digital or DTS--both encoding and decoding. Otherwise, the audio stream will default to 2-channel PCM. Over AMD's HDMI, you'll need an HDMI receiver for 6-/8-channel operation--otherwise, it'll default again to PCM.
A problem I've noticed is that the video from my HTPC isn't centered properly on the screen and seems grainy. It's using the HDMI interface so I don't really know what the problem is (or rather, how to fix it). Online searches said that I should disable the HDMI audio component but that did absolutely nothing.polkaudio Monitor 5 Series II
polkaudio SDA-1 (with the SL1000)
TEAC AG-H300 MK III stereo receiver
beyerdynamic DT-880 Premium (600 Ω) headphones
SENNHEISER HD-555 headphones
Little Dot MK IV tube headphone amp
Little Dot DAC_I balanced D/A converter -
Looking under device manager I find this?
Sound
Hauppauge WinTV HVR-2250 (8851)
High Definition Audio Device
RealTek High Definition Audio
The later two state internal bus 0
Also under Sound in Control panel it's states 2 channel mode via HDMI.
Still confused on how to change this.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
Joe, you should have a listing for ATI HDMI Output under your "Playback Properties" (assuming your using Vista or Win 7). Thats what you want to have selected.
You also might want to ensure you have the most updated ATI drivers for your card as well."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
EndersShadow wrote: »Joe, you should have a listing for ATI HDMI Output under your "Playback Properties" (assuming your using Vista or Win 7). Thats what you want to have selected.
Will look later, and yes Win 7
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Control Panel -> Hardware and Sound -> Sound -> AMD HDMI Output (Under Playback tab) - Right click and select properties. This will open a new window, select the last tab which will show you your sample rates.
What's selected and checked off here?
Too bad you wern't in the market, I'm selling my HTPC
disneyjoe7 wrote: »Looking under device manager I find this?
Sound
Still confused on how to change this.Control Panel -> Hardware and Sound -> Sound -> AMD HDMI Output (Under Playback tab) - Right click and select properties. This will open a new window, select the last tab which will show you your sample rates.
This is what I got under "Sound", like its not there.
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
That's strange.
I would disable the Realtek crap completely, reinstall your video card drivers from AMD and restart your machine. Do you have simultaneous connections utilizing your onboard and video card? (e.g. - Using HDMI out from video card for video and HD audio and using coax out from the motherboard or HDMI out from the motherboard?) You should really use one output for sound.
I just sold the same video card as what you have and had it paired with the same motherboard you have so I know it's a working combination. -
I'm only using the HDMI output via the video card which goes from the HTPC to the AVR, and the AVR to the TV.
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Disneyjoe, this post over at xbmc.org should explain how to resolve your problem:
http://forum.xbmc.org/showpost.php?p=688708&postcount=1
Apparently the important step is step 2. The audio chipset on the ATI graphics card is provided by Realtek, and apparently you get more features enabled when you install the Realtek driver in addition to the one provided by ATI. You can find the Realtek driver here:
http://www.realtek.com.tw/downloads/
Click High Definition Audio Codecs, accept the agreement, then download one of the top two choices, depending on if your OS is 32- or 64-bit.
Monster AVL-300, HTS-2500 MKII -
That's strange.
Drenis,
I did just what you stated, restarted WMC and to my surprise DD5.1....
Thanks and this forum has saved me some $$ and some extra time playing with everything over and over again.
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
disneyjoe7 wrote: »
I Love it NOW! I could play that over and over again it shacks the whole house. :cheesygrin:
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Glad it's working as it should.
Glad to hear you got everything working!!polkaudio RT35 Bookshelves
polkaudio 255c-RT Inwalls
polkaudio DSWPro550WI
polkaudio XRT12 XM Tuner
polkaudio RM6750 5.1
just my two cents, and this is not spam ha I was actually planning on building a HTPC but moneys so damn tight right now. And I had an amazon gift card sitting around that needed to be used.
I just picked up a Pivos Aios. For the price, especially for what it does, makes it a great option for someone who wants the whole HTPC without having to build or fork over a lot of money to get one.
Amazon has them for 89.99 and Pivos is doing a mail in rebate right now for 20 bucks. So shelling out 70 dollars for something this cool really isnt that bad of a thing.
Theres a TON of support for this thing, offical firmware updates and unofficial ones as well to customize it to your hearts content.
http://pivos-aios.wikidot.com/
Home Theater Setup- Receiver - Onkyo TX-RZ1100
- Mains - Polk RTi A9's
- External Amps - Outlaw 2200 Monoblocks for L/R/C
- Center - Polk CSiA6
- Side Surrounds - Polk FXiA6's
- Atmos - 4 Polk 80F/X RT's
- Sub - SVS PC-4000
- T.V. - LG OLED65C7P
Not really a HTPC... More comparable to a WD TV Live Hub.
you're right in the sense if you want anything other then to play movies or music, you'd probably wanna go with a HTPC. But I'd assume most people just wanna use it to play movies. And seeing how Sony keeps gimping the ps3, and locking out the ability to play different files (copyright or not), its a good CHEAP option. I still would love someday to build a real HTPC, but it'll probably be just a good gaming rig that happens to be hooked up to my TV ha
and on a side note, WD TV live hub (and all its other versions), are becoming useless. To many "mainstream" players are folding under the studios pressure to block out certain content, which negates the reason to even own a device like thatHome Theater Setup- Receiver - Onkyo TX-RZ1100
- Sub - SVS PC-4000
So how does a device like that play a movie? I mean does it play a DVD or just stream? Having built a HTPC I would say not having a tuner for OTA signal's it's more like a large paper weight.
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Streaming only. Either Netflix/Hulu or from a home server. I'd rather spend the extra to get a Squeezebox or build a real HTPC.
I wish I could use something like that as a media extender vs. a xbox much cheaper.
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
nope, not just streaming. Works off a bunch of things actually. Wifi for one, DLNA, FTP, memory card, RAID system, or installing a 3.5" HDD inside. Loads of different options.Home Theater Setup
- Sub - SVS PC-4000
disneyjoe7 wrote: »I wish I could use something like that as a media extender vs. a xbox much cheaper.
and you can trust me, if you have it hook up via DLNA, that skys the limit if you have another computer located in a different part of your house, but dont feel like moving it right next to your television.Home Theater Setup- Receiver - Onkyo TX-RZ1100
- Sub - SVS PC-4000
and just on a completely side note, I have Directv with a DVR, so I kinda have that base covered. The pivos is more for downloaded or ripped movies/tv shows/music more then anything elseHome Theater Setup
- Sub - SVS PC-4000
