Building a HTPC....
1235»
  • Bobsama
    Bobsama Posts: 526
    edited February 2012
    On a sidenote, something I discovered:
    Multichannel out over digital interfaces usually requires Dolby Digital or DTS--both encoding and decoding. Otherwise, the audio stream will default to 2-channel PCM. Over AMD's HDMI, you'll need an HDMI receiver for 6-/8-channel operation--otherwise, it'll default again to PCM.
    A problem I've noticed is that the video from my HTPC isn't centered properly on the screen and seems grainy. It's using the HDMI interface so I don't really know what the problem is (or rather, how to fix it). Online searches said that I should disable the HDMI audio component but that did absolutely nothing.
    polkaudio Monitor 5 Series II
    polkaudio SDA-1 (with the SL1000)
    TEAC AG-H300 MK III stereo receiver
    beyerdynamic DT-880 Premium (600 Ω) headphones
    SENNHEISER HD-555 headphones
    Little Dot MK IV tube headphone amp
    Little Dot DAC_I balanced D/A converter
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    Looking under device manager I find this?
    Sound
    Hauppauge WinTV HVR-2250 (8851)
    High Definition Audio Device
    RealTek High Definition Audio
    The later two state internal bus 0
    Also under Sound in Control panel it's states 2 channel mode via HDMI.
    Still confused on how to change this.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
    EndersShadow Posts: 17,704
    Joe, you should have a listing for ATI HDMI Output under your "Playback Properties" (assuming your using Vista or Win 7). Thats what you want to have selected.
    You also might want to ensure you have the most updated ATI drivers for your card as well.
  • disneyjoe7
    Will look later, and yes Win 7
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • Drenis
    Drenis Posts: 2,871
    Control Panel -> Hardware and Sound -> Sound -> AMD HDMI Output (Under Playback tab) - Right click and select properties. This will open a new window, select the last tab which will show you your sample rates.
    What's selected and checked off here?
    Too bad you wern't in the market, I'm selling my HTPC :(
  • disneyjoe7
    disneyjoe7 wrote: »
    Sound
    Drenis wrote: »
    This is what I got under "Sound", like its not there.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • Drenis
    Drenis Posts: 2,871
    That's strange.
    I would disable the Realtek crap completely, reinstall your video card drivers from AMD and restart your machine. Do you have simultaneous connections utilizing your onboard and video card? (e.g. - Using HDMI out from video card for video and HD audio and using coax out from the motherboard or HDMI out from the motherboard?) You should really use one output for sound.
    I just sold the same video card as what you have and had it paired with the same motherboard you have so I know it's a working combination.
  • disneyjoe7
    I'm only using the HDMI output via the video card which goes from the HTPC to the AVR, and the AVR to the TV.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • Syndil
    Syndil Posts: 1,582
    Disneyjoe, this post over at xbmc.org should explain how to resolve your problem:
    http://forum.xbmc.org/showpost.php?p=688708&postcount=1
    Apparently the important step is step 2. The audio chipset on the ATI graphics card is provided by Realtek, and apparently you get more features enabled when you install the Realtek driver in addition to the one provided by ATI. You can find the Realtek driver here:
    http://www.realtek.com.tw/downloads/
    Click High Definition Audio Codecs, accept the agreement, then download one of the top two choices, depending on if your OS is 32- or 64-bit.
  • disneyjoe7
    Drenis wrote: »
    That's strange.
    Drenis,
    I did just what you stated, restarted WMC and to my surprise DD5.1....
    Thanks and this forum has saved me some $$ and some extra time playing with everything over and over again.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • disneyjoe7
    disneyjoe7 wrote: »
    I Love it NOW! I could play that over and over again it shacks the whole house. :cheesygrin:
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • Drenis
    Drenis Posts: 2,871
    Glad it's working as it should.
  • Serendipity
    Serendipity Posts: 6,975
    Glad to hear you got everything working!!
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
  • Theheadsn
    Theheadsn Posts: 413
    just my two cents, and this is not spam ha I was actually planning on building a HTPC but moneys so damn tight right now. And I had an amazon gift card sitting around that needed to be used.
    I just picked up a Pivos Aios. For the price, especially for what it does, makes it a great option for someone who wants the whole HTPC without having to build or fork over a lot of money to get one.
    Amazon has them for 89.99 and Pivos is doing a mail in rebate right now for 20 bucks. So shelling out 70 dollars for something this cool really isnt that bad of a thing.
    Theres a TON of support for this thing, offical firmware updates and unofficial ones as well to customize it to your hearts content.
    http://pivos-aios.wikidot.com/
    Home Theater Setup
    • Receiver - Onkyo TX-RZ1100
    • Mains - Polk RTi A9's
    • External Amps - Outlaw 2200 Monoblocks for L/R/C
    • Center - Polk CSiA6
    • Side Surrounds - Polk FXiA6's
    • Atmos - 4 Polk 80F/X RT's
    • Sub - SVS PC-4000
    • T.V. - LG OLED65C7P
  • Syndil
    Syndil Posts: 1,582
    Not really a HTPC... More comparable to a WD TV Live Hub.
  • Theheadsn
    Syndil wrote: »
    you're right in the sense if you want anything other then to play movies or music, you'd probably wanna go with a HTPC. But I'd assume most people just wanna use it to play movies. And seeing how Sony keeps gimping the ps3, and locking out the ability to play different files (copyright or not), its a good CHEAP option. I still would love someday to build a real HTPC, but it'll probably be just a good gaming rig that happens to be hooked up to my TV ha
    and on a side note, WD TV live hub (and all its other versions), are becoming useless. To many "mainstream" players are folding under the studios pressure to block out certain content, which negates the reason to even own a device like that
    Home Theater Setup
    • Sub - SVS PC-4000
  • disneyjoe7
    So how does a device like that play a movie? I mean does it play a DVD or just stream? Having built a HTPC I would say not having a tuner for OTA signal's it's more like a large paper weight.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • magicka
    magicka Posts: 11
    Streaming only. Either Netflix/Hulu or from a home server. I'd rather spend the extra to get a Squeezebox or build a real HTPC.
  • disneyjoe7
    I wish I could use something like that as a media extender vs. a xbox much cheaper.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • Theheadsn
    nope, not just streaming. Works off a bunch of things actually. Wifi for one, DLNA, FTP, memory card, RAID system, or installing a 3.5" HDD inside. Loads of different options.
    Home Theater Setup
    • Sub - SVS PC-4000
  • Theheadsn
    disneyjoe7 wrote: »
    and you can trust me, if you have it hook up via DLNA, that skys the limit if you have another computer located in a different part of your house, but dont feel like moving it right next to your television.
    Home Theater Setup
    • Sub - SVS PC-4000
  • Theheadsn
    and just on a completely side note, I have Directv with a DVR, so I kinda have that base covered. The pivos is more for downloaded or ripped movies/tv shows/music more then anything else
    Home Theater Setup
    • Sub - SVS PC-4000
